Old 02-03-2023, 10:58 AM   #1
2022 27' Flying Cloud
REXFORD , NY
Window grommets/cap washer
So I need new snap cap washers for my roadside left rear most window on my 2022 FC 27FB. Everyone has the ones for the hinge screws. Part # 0802-004 . But no one seems to know about or have the ones for the closure brackets. ( I’ve searched the web and talked to two dealers ). The ones for the brackets look similar but have a hub to go into the hole in the glass and protect it from the screw. I found one reference to a part update/ substitution but it was a dead end. Also there is either double sided tape or foam tape that’s become sticky, On the closure brackets. Again no good answers yet. Any help would be appreciated. Especially part numbers or web sites. Thanks
TOLLERNUS is offline   Reply With Quote
Old 02-04-2023, 08:52 AM   #2
REXFORD , NY
Ok, figured out that the “hub” I was describing is actually a “window glass mounting spacer” part # 382357. and not attached or part of the snap cap cover. Problem solved thanks to those who looked in in it.
Neoprene washer with cap jasfox Plumbing - Systems & Fixtures 0 07-12-2015 09:59 AM
Stove top grommets. ROBERTSUNRUS Stoves, Ovens & Microwaves 12 09-17-2012 07:20 PM
New grommets for my rock guards willbrackman Rock Guards, Segment & Window Protectors 2 01-01-2012 07:14 AM
Leaf spring suspension grommets Scott S Axles 10 06-02-2008 07:26 AM
shower curtain "cap like" grommets Neenm Upholstery, Blinds, Walls & Interior Finishes 0 08-03-2002 02:04 PM
