Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 08-07-2020, 03:50 PM   #1
1968 28' Ambassador
1964 17' Bambi II
Portland , OREGON
What kind of glue should I use to put in a small vista window?
Hello,
I've been working towards improving the windows on my 1968 Airstream Ambassador. I have successfully put in a Corning window that was missing when the trailer was purchased.
Although, I noticed one of the small vista windows in the front of the trailer was replaced by the previous owner with plexi glass. So, I went and got some car glass custom cut. Luckly this window is flat so I saved a lot of money not having to purchase curved glass.
My issue is that I don't want to use silcone as a glue to install the glass. So I'm wondering what adhesive would be compatible with glass and aluminum, but also safe to use on the Airstream?
Thank you for the help!
-Megan
megan1968 is offline   Reply With Quote
Old 08-07-2020, 05:24 PM   #2
2000 25' Safari
Denver , North Carolina
SEALANTS: SUMMARY :
Taken from previous Thread on sealants. Copy and paste put it in a document.Print and SAVE
NO SILICONE:
For wheel wells/underbody:
Vulkem 116
Trempro 635 Grey
Sikaflex 221 Black (use Eternabond spray cleaner to prepare surface)
Adseal Premium Quality Sealant Grey
Roof:
Sikaflex 221 White (for roof seams, seals and bonds. Use Eternabond spray cleaner to prepare surface)
Sikaflex 715 (around fans, vents, skylights ... self-levelling)
Adseal Premium Quality Sealant White
Dicor self-levelling sealant
EternaBond® AlumiBond (alum. backed sealing tape, 2", 3", 4", and 6" wide)
Lexel™ Clear
Windows/Trim/Rubrail/Exterior Lights:
Sikaflex 221 Grey (seals and bonds. Use Eternabond spray cleaner to prepare surface)
Parbond Grey or Clear (small hand tubes, prep and clean-up use cosmoline remover)
Trempro 635 Grey
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant
Lexel™ Clear
Small seams (between aluminum panels):
Acryl-R (available in cans from Airstream store. Use applicator or disposable syringes to apply)
Aluminum Pigmented Gutterseal
Rivet sealer:
Captain Tolley's Creeping Crack Cure
Parbond Gray or Clear (small hand tubes), also good for small gaps (<1/8”) such as top of belt line rub rail, door/window frames, etc
mbubbaca is offline   Reply With Quote
Old 12-25-2021, 09:41 AM   #3
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
Originally Posted by mbubbaca View Post
SEALANTS: SUMMARY :
NO SILICONE:
Vulkem 116
Trempro 635 Grey
Roof:
Lexel™ Clear
Trempro 635 Grey
Lexel™ Clear
Rivet sealer:
Where can Adseal Premium Sealant be purchased?
Thank!
Using Automotive Windshield Adhesive to glue Vista View windows back in H.Huester Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 01-13-2018 11:23 PM
Glue or not to glue carver 1 Floor Finishes 15 06-15-2015 06:12 AM
What are the inside end caps made of? Glue to use? ventport All Argosy Trailers 7 07-08-2012 12:21 PM
What glue should I use to fix a small crack in my freshwater tank? JimGolden Fresh Water Systems 4 06-11-2009 04:22 PM
