Old 01-17-2021, 10:57 PM   #1
1965 24' Tradewind
Dolores , Colorado
Replacing glass on 1965 Airstream Tradewind 24'
I am planning on replacing two windows on my 1965 Airstream Tradewind 24'. Can i just replace with regular glass and then seal it with silicone?
I currently have shattered glass removed but it has a thin black strip on there. I am guessing that is an adhesive to bind glass to frame?
Thank you.
T
Time4fun is offline   Reply With Quote
Old 01-18-2021, 05:47 AM   #2
1966 22' Safari
Fredericksburg , Texas
T, you should get tempered glass. On our 66, the 1/8” tempered glass slid into a top bar. I had to run a drill bit perpendicular to the bar in the slot to enlarge it slightly to receive the glass. The black stuff was glazing tape used for typical framed windows. Good luck
Bubba L is offline   Reply With Quote
Old 01-18-2021, 10:37 AM   #3
1965 24' Tradewind
Dolores , Colorado
Bubba, I had read that trailers before 66 used regular glass but was really unsure. Did you think Tempered glass would work for either 65 and 66 trailers? I am very inexperienced and am learning as i go. Did you just have a glass company cut the glass for you then?
I got most of the silicone out of the tracks on the window frame and it seems straight forward but.........
Thanks.. T
Old 01-18-2021, 11:13 AM   #4
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
65 are flat glass windows 1/8 tempered, tinted if you want. Buy anywhere. Add glazing tape.
66 (67 and 68) are curved Corning glass still made by Airstream and sold by VTS.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 01-18-2021, 11:59 AM   #5
1966 22' Safari
As Hittenstiehl pointed out, the street and curb side operable windows of the 66, 67 and 68 years had the chemical treated curved windows. The ones I had to replace were the front, rear and an inoperable one forward of the door which were all flat panes. I actually had two different glass suppliers I used for both our trailers. So yes, just order from a local glass shop. I think it is important for safety and durability to replace any flat pane with tempered on any year model.
Old 01-19-2021, 10:48 AM   #6
1965 24' Tradewind
Dolores , Colorado
Bubba, Copy that! Im really starting to figure out the little differences in these trailer years. But, i figured id asked the forum so i can avoid issues down the road. Again, thanks for your help. I dont know why, but the forum feels like a group of long lost friends. So, thank you. T
Replacing window glass in '50s Airstream zgears Windows, Doors, Locks & Vents 3 03-03-2012 07:36 PM
replacing windows - glass, lexan, tempered glass? BrianY Windows & Screens 4 07-01-2010 12:08 PM
Replacing back glass on '75 Sovereign rickastream Windows & Screens 13 07-15-2009 01:32 PM
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
replacing glass fuses with blades maznblu Electrical - Systems, Generators, Batteries & Solar 4 08-05-2003 11:34 PM
