Old 06-12-2020, 03:58 PM   #1
2019 19' Flying Cloud
2006 16' International CCD
Front Range , CO
Range Vent Flapper
When the wind come up in the evening the range vent flap makes noise banging around until I finally go out and secure it.
Is there a hack for this?
Tried the site searh and xyz site:airforums.com search with no joy.
trailerpup is offline   Reply With Quote
Old 06-12-2020, 04:04 PM   #2
NukeSubSailr's Avatar
2010 20' Flying Cloud
Surry , Virginia
Yes, outside on the side of the flap is a little latch to secure it during travel.
NukeSubSailr is offline   Reply With Quote
Old 06-12-2020, 06:47 PM   #3
"Cloudsplitter"
I use a custom spring actuated wind stream removable,(when brain fart causes failure to remove) gizmo.🥴
Added benefit...more flow less fan noise when door held open.👍
ID:	370144   Click image for larger version
Iím done with ĎadultingíÖLetís go find Bigfoot.
Old 06-12-2020, 08:55 PM   #4
Front Range , CO
Brilliant!
Did you make the gizmo on a 3d printer?
Old 06-13-2020, 05:29 AM   #5
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Originally Posted by trailerpup View Post
Brilliant!
Good one!
Old 06-13-2020, 06:31 AM   #6
Rich W's Avatar
I'm In , Kentucky
That looks pretty ingenious. I wonder if it might have any other uses.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 06-13-2020, 07:56 AM   #7
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
the std vent has 2 SS clip that are meant to rotate in place when traveling , is windy or the stove is not in use.
take a closer look. I would be surprised if the clips are missing
waninae39 is offline   Reply With Quote
Old 06-13-2020, 12:04 PM   #8
Front Range , CO
The little holder clips are still there and work fine when engaged.
The problem is after cooking at night I forget to engage the clips. After going to bed, when the wind comes up, the flapper starts flapping and banging around necessitating a quick run around the trailer in the dark to secure the flapper.
Gonna go see if I can find a gizmo in aluminum or stainless for the esthetic.
Old 06-17-2020, 05:21 PM   #9
Steamguy's Avatar
2024 19' Caravel
Washougal , Washington
I saw another solution for this same kind of thing on a different forum, way long ago. The poster had super-glued a couple of steel washers on the outside of the flap, and a couple of weak magnets on the coach body side of the flap. He glued the magnets on the bottom inside corners of the duct, and the steel washers were placed over where the magnets could attract them.
He had a lot of trial-and-error to get the amount of 'stick' right, but the idea was that as the flap closed, the magnets would hold it closed; then when he turned on the fan, the air pressure from the fan would 'pop' the flap open and the range fan functioned.
When he shut the fan off, the air pressure decreased, and the flap closed.
Sort of an automatic thing here, if you get the idea.
Steamguy
2024 Caravel 19CB
"Dot"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 05-19-2024, 11:46 AM   #10
Rich Jenkins's Avatar
2019 25' Flying Cloud
Ocala , Florida
Did a search to find this thread.
On my new to me FC 25RBT, the range hood vent is in fact missing the two turn buttons that would normally hold the flap closed. All I have is a couple holes.
Iíve sourced a complete external vent cover at Woodland Airstream for under 40, including the gasket set. I can do that, or just use a commercial plastic or aluminum turn button there, but I thought Iíd ask, does anyone know of a source for the original vent hood turn buttons that come with the hood cover?
ďCharacter is doing the right thing when nobodyís looking. There are too many people who think that the only thing thatís right is to get by, and the only thing thatís wrong is to get caught.Ē - J.C. Watts Jr.
Rich Jenkins is offline   Reply With Quote
Old 05-19-2024, 12:09 PM   #11
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
In my opinion if the vent is old enough to be missing the turn buttons, it's old enough to be replaced. The plastic on these (like all plastic parts) can become brittle and suddenly crack when you touch it.
Take the opportunity to replace it now, in your driveway and on your schedule, rather than on the road somewhere after you pull into a campsite and discover that half of it is missing.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 05-19-2024, 02:18 PM   #12
Ocala , Florida
Thanks Richard. That’s a fair point.
Old 05-19-2024, 02:44 PM   #13
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by Rich Jenkins View Post
Thanks Richard. Thatís a fair point.
Except those 'turn buttons" are not secured well. I lost one after a few years, well before plastic degradation was an issue.
2019 Ford Expedition Platinum
Wayne&Sam is online now   Reply With Quote
Old 05-19-2024, 03:50 PM   #14
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
If all is well, except that the flapper turn /lock piece has come off, then I have used industrial sticky back velcro to secure the flap closed during travel. Just use 2 smaller pieces of velcro A on the flap, and the frame, and then a piece of the velcro B about the size of a 2 inch piece of scotch tape to run across the frame connecting both of the A pieces. (do on each end)
Bonus that when you are camped and the barometric vent hood relief damper is open you can simply hang piece B on the piece A on the frame so it doesn't get lost.
Piggy Bank
Piggy Bank is offline   Reply With Quote
New Tires - got Load Range E instead of Load Range D Hyperion 2009-2015 Flying Cloud 49 06-08-2016 06:47 PM
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Replace range/oven with range/microwave rkconway Stoves, Ovens & Microwaves 2 01-13-2009 03:58 PM
64 Safari broken (original) toilet flapper shinybean Sinks, Showers & Toilets 0 02-19-2008 10:13 AM
Toilet flapper loses standing water Armorhotdog Sinks, Showers & Toilets 8 05-10-2006 08:37 AM
