It might help if you could describe the problem you are having with getting the skin back on. If it is a matter of the holes not lining up, it sounds like your door frame was warped, sprung, or otherwise only being held in shape by the inner skins, and when they were released, it changed shape.
If this is the issue, the first thing I would do is try "dry-fitting" the door to the door frame and see if it is a good fit. If it is not, then bend the door as needed until it is a good fit, and then check to see if the holes line up on the skin. IF they don't then you may have to drill new ones.
good luck!
