August, 2023
My 2018 International has a wimpy interior door handle. This past Sunday evening, while trying to secure the door for the night at my campsite, my tug sent me flying backwards holding the handle. So, locked INSIDE. with the screen door blocking access to two of the screws that secure the door mechanism, I was left with the option to use the rear exit in the morning. Fortunately, my late husband had a Fiamma bike rack installed upon buying the trailer. That provided a step down after getting out the rear window. Great planning with the bike rack, do not get any other kind. It cleared the window opening by around an inch! With a pillow on top I was able to exit without having to catch the eye of a neighbor camper and ask him to open my door. The door latch inside handle is extremely poorly designed, as there is ONE tiny screw holding that handle on. Since the door needs a pull to latch, that weak spot eventually had to give. Just so I did not lock myself in again each night, I used a simple tie down on the screen to my interior door handle which is attached to the wall with 4 SMALL screws. These are not going to save you from falling like a safety bar. Be careful. Following along some earlier comments on this subject, I found the fix. Good luck. Find a substantial handle that will be around 5 inches and drill holes to attach. See some of the images
Best of luck
