exterior entry door hits frame
Hello -- I can't seem to find a match for this problem in other threads. My entry door is sagging at the bottom such that the bottom corner, latch-side, comes into contact with the outer edge of the trailer. Therefore it won't fully fit into the opening.
I've tried to square it up by loosening the hinges and lifting up on the door while also putting pressure toward the top hinge. This helped a little but it still comes into contact at the bottom, so it's not a sufficient fix.
A related problem, or perhaps the cause, is that the door itself is bent (to such an extent that when it is closed, I can stick my fingers out the top corner). I've read a lot about that issue here so not asking for particulars about solving that problem -- unless that's the solution to my sagging door as well. But my main concern at present is just getting it to close fully, so I wanted to see if there was a common solution that I'm missing to lifting up the door a little bit.
Thanks for the feedback!
