Old 02-06-2022, 04:59 PM   #1
1972 31' Sovereign
Cooper , Texas
Door Lock Repair 1972
Is anyone aware of a facility that can repair or sells parts for the door lock on a 1972 Airstream? After 50 years of use, some of the parts need to be replaced. Thanks for your ideas.
keepontravln is offline   Reply With Quote
Old 02-06-2022, 05:06 PM   #2
1966 22' Safari
Fredericksburg , Texas
Try Montanablue here on the Forums. Rick is the go to guy for vintage door hardware.
Bubba L is offline   Reply With Quote
Old 02-07-2022, 08:32 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Vintage Trailer Supply has a surprisingly large array of parts for the KT latches:
https://www.vintagetrailersupply.com...page?q=KT+lock
You might also try outofdoorsmart.com or inlandrv.com
good luck!
Old 02-07-2022, 06:56 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
I removed the old KT lock on my 75 Overlander and replaced it with a standard RV lever lock from Korhee. It is very robust, has been made for years, is at a reasonable cost. It has a built in deadbolt which is a plus. And it has an inside door pull. The KT lock didn't have this and we would pull the door shut with the opening lever. I think that is one design defect of the KT lock. Korhee sells it in chrome which works for an Airstream seems to me. The cost was less than $60. It just takes some time to install the thing, and it isn't original. So far, so good.
I agree montanablue is the Forums Airstream lock guy.
David
Name:	2105 Korhee Lock Outside-800x600.JPG
ID:	411729   Click image for larger version
Name:	2105 Korhee Lock Inside-800x600.JPG
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 02-08-2022, 05:57 PM   #5
Tom T
Tom_T's Avatar
Orange , California
good luck!
Ditto for VTS. You'll need to get the door handle/lock type & model number, and what part(s) is/are broken - then check on their website.
Our Bargman on our 1960 Avion T20 had a broken slide, which part I was able to get from VTS, pulled the lock off, replaced the slide & reinstalled within an hour.
I added another 45 mins to repeat the process when I installed the lock tumbler in reverse - so keep track of it on yours to save the second round!
They're not hard to DIY if you can get the needed parts, & keep track of their orientations during disassembly.
Good Luck!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Changing door lock to home lock airking Windows, Doors, Locks & Vents 20 04-26-2022 07:24 AM
1972 door latch/lock help Emmaggy Doors & Locks 2 10-22-2020 05:07 PM
Thief damaged my FC cargo door lock attempting to gain entry now key wont open lock luckysgt663 Doors & Locks 14 04-01-2019 02:57 PM
Door Lock For 1972 Overlander (Full Assembly) AudreyMyLove Airstream Classifieds 0 10-04-2017 01:33 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
