Old 05-06-2021, 12:02 PM   #1
1980 20' Caravelle
Bellingham , Washington
Curved front side window
Shattered curved street side window on 20 ft 1980 Caravelle Airstream. Tapped glass with strapping tape inside and out for temporary use. Being a 7 ft wide I couldn't find a replacement so did it myself. Used punch for a starting point for drilling ou all 38 rivets with 3/16 drill
Then pounded out strip holding side of window frame not having any rivets. Cleaned out broken glass and all putty. Pried frame out and made template out of poster board. Used .22 thickness Acrylic piece from Home Depot. Cheaper than lexan not available in thick enough piece without ordering it. It doesn't yellow as easily I learned. Cut piece using fine blade on saber saw which worked well. Took some tries to get piece right size by fitting it into frame several times. This is after removing two small screws holding frame together and leaving film on the acrylic piece. Also used blow dryer in the sun to help bend into frame. Used silicon on frame for final fitting. Used 5/ 32 Olympic shavable rivets and cut off remains with drummel and also Used to sand off to look most like original rivets. My Caravelle has less curved area on the front side windows than on the Argosy Minuet so is easier to replace I believe.
jwkiefer is offline   Reply With Quote
Old 05-06-2021, 12:54 PM   #2
1972 23' Safari
Middletown , Rhode Island
Any pics???
Mx468 is offline   Reply With Quote
Old 05-07-2021, 11:35 AM   #3
1980 20' Caravelle
Curved front window
Only 3 pictures. Damaged, window out and finished.
ID:	395037   Click image for larger version
Old 05-07-2021, 12:21 PM   #4
1980 20' Caravelle
One correction. Think I used 5/32 drill to drill out rivets instead of what I said was 3/16 in my post.
Old 09-09-2021, 08:38 PM   #5
WHUDS22's Avatar
2018 25' Flying Cloud
Arcadia , Oklahoma
Looks good
WHUDS22 is offline   Reply With Quote
1977 Argosy front curved window (curb side) rachelj Airstream Classifieds 0 08-09-2018 09:17 PM
1988 Excella replaced curved front side window assembly coloradopete Windows, Doors, Locks & Vents 0 08-31-2014 02:36 PM
broken curved window curb side HELP charliesclas Windows & Screens 14 09-03-2007 07:08 AM
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 09:20 AM
