Adjustment, maybe, maybe not.
Look closely at the bullet latch. Does it have a strong push on the plastic bullet or is it a bit lazy? Mine had a broken spring really lazy. Drilled out 4 rivets and now its assessment time. Replace the broken spring or the entire bullet latch assy? I found a spring at hardware store that could have fixed my lazy latch but a new latch was in hand.
