02-06-2017, 06:09 PM
Gilbert
where to find a stainless steel shower pan
im building a bathroom from scratch and would really like to use a stainless steel shower pan. ive seen plenty of pictures of custom restorations but when I google search for a stainless pan I have very few options. im not bound to any specific measurements since I have a gutted trailer at this time. so where are people finding these?
02-06-2017, 06:55 PM
1972 25' Tradewind
North Vancouver
, British Columbia
Most likely need a metal fabricator to make one for you.
North Vancouver, BC
02-06-2017, 07:38 PM
1978 31' Excella 500
Genoa
, Nevada
Growth challenge for you: If you're attempting a trailer gut, you are probably quite handy around tools. Study up, buy a welder, make your own stainless pan. You can weld stainless with SMAW stick with stainless rods but it will stain, if you're worried about the stain then you might want to study up on a process that has an inert gas to keep the air off the stainless while you are welding.
In the end you'll have a new trick in your bag, and something you built. And perhaps cheaper than farming it out even. Preheat is good, and let it cool slowly.
http://www.wikihow.com/Weld-Stainless-Steel
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
02-06-2017, 07:39 PM
Biloxi
, Mississippi
Have you tried Lowes?
MICHAEL
02-07-2017, 09:30 AM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Amazon has a Kohler pan listed.
Vary your searches to more commercial or restaurant direction and that may get you better results.
Hittenstiehl
02-07-2017, 10:14 AM
You'll not likely weld thin gauge stainless steel successfully using the SMAW process as the heat input is too high and significant warpage (which is a constant issue with stainless) will occur. A better option would be GTAW, or possibly GMAW-S, however the equipment costs for these processes are a bit higher.
The "stain" is oxidation caused by the welding heat input. This can usually be removed with by passivation, or a pickling paste.
Unless you're skilled in metal fabrication, I'd sub this to a capable fabricator if an off the shelf unit is not an an option.
Regards,
Kevin
William C. Swinney
02-07-2017, 11:33 AM
1962 28' Ambassador
Mesa
Sometimed the guys at the sheet metal shop of the Air Conditioning Refrigeration company's enjoy doing fun things like stamping out a nice shower pan for your specs.
Hittenstiehl
02-07-2017, 11:39 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Exactly. We had ours custom made...
Shari
02-07-2017, 01:33 PM
1964 26' Overlander
Rancho Palos Verdes
Ctaulborg has a similar problem. Looks like he's going to get a custom pan from Hoffman. See the bottom of post #29 in this thread:
http://www.airforums.com/forums/f179...-161419-3.html
02-07-2017, 11:28 PM
2021 27' Globetrotter
Fort Lauderdale
Not an expert but SS does stain, which means rust. The first S stands for stainLESS not stain-not. We had to remove rust from SS year round on our sailboat. Would an alternative material in the plastic family do the trick and work better/longer? Like the pans in our homes showers.
GT 27 2021, F250 2022 Platinum- 2022 Tesla X - 2021 Ford Mustang Mach E - 2022 Tesla 3 - PP3 hitch
GSD Sigrid - Fort Lauderdale, FL; Denver and Summit County, CO.
