I can't see where it comes from, but my trailer has a similar faucet near the city water inlet. It is just a cold water outlet. In my trailer, under the bathroom sink there is a check valve in line with it and a valve bypassing the check valve. I think I figured it out. The check valve is above the water pump pressure but below typical city water pressure. With the bypass valve closed, the outside faucet works when connected to city water but doesn't work when boondocking using water out of the tank with the pump. With the valve open the outside faucet always works.
