Old 09-16-2023, 10:43 AM   #1
Titusville , NJ
What is function of these two water drain lines near Grey Water Tank?
Hello, while doing some work on the underside of my 2012 AS FC 23 I noticed these two water lines protruding through the base of the AS. They are located just street side of corner of the grey water tank. The red (hot water?) line is capped off but the white (cold) is not. Is this by design or should I cap off the white line as well? What is their function?
Thanks in advance!Click image for larger version
cfrench58 is offline   Reply With Quote
Old 09-16-2023, 11:23 AM   #2
2015 30' International
FREDERICK , Maryland
Those are your low point drains (hot and cold) for theoretically draining out all of your pipes. I have not seen one capped like that though? Neither of mine are capped. I only use them when I winterize or sanitizing the fresh water tank and water lines in the spring when I de-winterize.
Doc Foster is offline   Reply With Quote
How do I access these leaky water lines? shanrhall Fresh Water Systems 7 12-27-2021 06:45 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 08:42 PM
Light on near black/grey water drain - how to turn it off? Nightwatch Lights - Interior & Exterior 4 01-02-2012 02:41 PM
Where do these other water lines go? adwriter73 Plumbing - Systems & Fixtures 9 09-28-2010 09:08 PM
