06-15-2025, 05:44 AM
Wetumpka
, Alabama
Wet floor between beds
Hello! On our recent camping trip, we noticed a large wet spot under the back of our camper on the ground (1991 Excella). I assumed it was condensation from AC, as we noticed several other campers had similar wet areas. About 1 week in to the trip, I noticed moisture in the floor between the beds. The side bins under the beds are dry and water pressure is good. Only wet spot is right in the middle of floor between beds. What is going on?
06-15-2025, 06:07 AM
1985 25' Sovereign
Navarre
, FL
Is the vent or A/C leaking?
06-15-2025, 06:26 AM
2018 27' Globetrotter
Mooresville
, North Carolina
This probably does not apply to your RV looking at the year of yours. We had the same issue and it was due to the front end separation issue. We were driving in heavy rain and water entered in the front storage compartment area and made its way between the beds.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
06-15-2025, 09:08 AM
1993 34' Excella
York
, South Carolina
Check the shore water inlet connection (where you connect the outside water hose), they are notorious to leak. On your model it is very likely mounted in the rear corner panel and would be near your reported water problem.
If it is leaking (from the back side) it would very likely run across the floor and pool in the area you describe. It could be as simple as a loose water line. Replacing it is a DYI project, you can find many threads here on how to.
Good luck.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
06-15-2025, 09:23 AM
2008 27' International FB
Petaluma
Do you have a dog? (Sorry, I couldn't resist) ;-)
Looking for adventure in whatever comes our way.
- Brad
06-15-2025, 01:44 PM
Wetumpka
, Alabama
The A/C is draining down the side. No condensation line.
06-15-2025, 01:51 PM
Wetumpka
, Alabama
Good luck.
John
I have checked the water inlet. It is not wet where it enters the trailer and there is still carpet in that bin and the carpet is not wet. It isn't wet anywhere except between beds.
06-15-2025, 01:52 PM
Wetumpka
, Alabama
My first thought. It wasn’t them.
06-16-2025, 04:51 AM
1993 34' Excella
York
, South Carolina
If the perimeter is all dry, yet the center is wet, it must be coming straight down from the roof vent or fan.
John
06-16-2025, 07:47 AM
1994 25' Excella
Waukesha
, Wisconsin
My guess is that some of the condensate is not going over the side but rather dripping through the vent(s) onto the floor below it.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
06-16-2025, 08:03 AM
Tampa
From reading your post I assumed you're not talking about rain.
If it's wet and not rain then it's either A/C or fresh water.
Is the A/C outlet damp? Any signs of a drip? No one witnessed it? Does it occur if you're NOT connected to city water? Do you leave the water pump on?
Conversely, if you shut off the A/C but leave the water system connected does it also happen? Try surrounding the area with paper towels to see it there's a trail from under a cabinet. Or sprinkle talc.
If the A/C runs off the roof, is it possible it's finding it's way past a window seal? Can you direct the drip off the roof by changing the 'level' slightly?
Try eliminating one thing at a time.
06-16-2025, 11:29 AM
Mooresville
, North Carolina
Don’t know where your toilet is but, is it possible the flush valve or inner seal (between the upper and lower bowl) is leaking and the water is making its way between your beds? You could turn off the water valve feeds to toilet to see if the dampness goes away.
"Roadrunner"
