Old 09-07-2020, 09:57 PM   #1
1992 29' Excella
PLANO , TX
way to reconnect pipe to valve
Airstream is 1976 27' rear bath overlander. I just discovered one of the cold and hot water copper pipe was broken near hot and cold water combine valve. My question is what is the way to reconnect the pipe to the valve?
Xin Li is offline   Reply With Quote
Old 09-08-2020, 03:27 AM   #2
Sag Harbor , New York
Welcome to the forum!
The failure of your old copper pipe suggests [IMO] that it may be time to start replacing the copper with PEX, and to replace that valve while you are at it.
https://www.google.com/search?q=PEX+...=airforums.com
Many threads in these search results concern vintage Airstreams like yours.
Good luck,
Old 09-08-2020, 11:22 AM   #3
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Xin Li I hope you enjoy your Airstream. I have a ‘76 trailer too and had several breaks in the copper pipes because of freezing during a previous owner. I changed all the piping to pex which wasn’t too hard.
Dennis
dennis3751 is offline   Reply With Quote
Old 09-09-2020, 08:00 AM   #4
1992 29' Excella
PLANO , TX
Dennis
Thanks. Is yours rear bath? Did you have to remove everything in rear bath to change all the piping to pex? Could you share how you did it?
Old 09-09-2020, 08:17 AM   #5
Mollysdad's Avatar
I've had good luck with rubber couplings.
I had a repetitive crack between an ABS drain pipe and brass shower drain. After replacing it a couple times, I added the rubber coupling. No more problems.
Old 09-09-2020, 09:25 AM   #6
1976 31' Excella 500
Chappell Hill , Texas
That's a bad solder joint where the pipe was inserted into the shower valve. I just had to re-solder one of mine last week. Google soldering copper pipe. IT's really easy. REMOVE THE CARTRIDGE SO IT WON'T MELT INSIDE THE VALVE.
Clean the joint surface inside the valve and clean outside the pipe with sand paper or Emory cloth,
add flux to inside of socket and outside of pipe,
insert pipe completely,
slowly heat pipe first with your propane torch, then move flame to valve socket keeping it facing toward the pipe,
add solder slowly until it's drawn in all the way around, Done.
tbashin is offline   Reply With Quote
Old 09-09-2020, 01:14 PM   #7
1970 23' Safari
Torrance , California
The couple shown in the post above is NOT for PRESSURIZED CONNECTIONS. It is a NOHUB Coupler used for waste and vent lines only. It will NOT hold pressure. Best bet is to solder as others indicated
1970 Safari is offline   Reply With Quote
Old 09-09-2020, 01:27 PM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Greetings from Colorado. I have a 75 Overlander 27 twin bed rear bath. I had many freeze splits in the copper plumbing that had been repaired with hoses and clamps. Not good. I replaced all the plumbing with modern PEX. Soldering copper tubing is a skilled trade that takes some practice. I've done it, but I'm not good at it.
Some shower valves come with threaded connections. I don't know what that reducing fitting is sticking out of your valve where the copper tube had been cut. Maybe it will unthread.
Some Forum members will cringe at this idea. I have had good luck with "Shark bite" fittings. They are very handy for "solderless" repairs. Maybe that is a possibility. I have 3 of them in my wife's Airstream and 10 years, no leaks.
Knowing our trailers, there isn't much room for plumbing work back there. Some "disassembly" required.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 09-09-2020, 03:12 PM   #9
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
That can be soldered, that is a reduction coupler should be an easy fix. Put a wet rag on the valve body to protect it. However I would start replacing with PEX. When and where ever you can get at it.
bibbs is offline   Reply With Quote
Old 09-09-2020, 03:48 PM   #10
dennis3751's Avatar
1976 29' Ambassador
Dennis
Sorry for the late response. I changed out the valve but it was fairly difficult. The bottom of the cabinet lifts out to give you a little access. Also you can get to some of this area through the low rear “trunk” door over the bumper. Most of the piping going forward to the kitchen and fresh water tank is easy to get to under the curb side bed.
Old 09-09-2020, 09:03 PM   #11
1992 29' Excella
PLANO , TX
Thanks for all your reply. I had to taken out the shell from the cabinet. Only my head can get in. There is very little room to do solder. Hard to solder it correctly.
I think I have to remove bathroom to redo all plumbing with pex.
Another question is how to remove toilet? where are the screws to fasten toiler to the floor?
Old 09-09-2020, 10:37 PM   #12
bibbs's Avatar
1975 26' Argosy 26
Vista , California
They are tricky to get to, try using a mirror so you can see inside from the back, the flange unscrews from the tank, if you need to remove that as well
Old 09-10-2020, 09:10 AM   #13
1992 29' Excella
PLANO , TX
Dennis
Hi Dennis, what fittings you used when you replaced all piping with pex? I read some where they said Sharkbites fittings is not good for RV.
Old 09-10-2020, 10:37 AM   #14
dennis3751's Avatar
1976 29' Ambassador
Xin
I used Sharkbite fittings since I couldn’t find a crimping tool under $200. They have worked for me but I do check things each season. I also bought red and blue tubing so it is easy to identify the hot and cold water.
Unable to reconnect to Victron 100/20 marter Generators & Solar Power 41 10-13-2018 05:35 PM
PEX Pipe: Best way to retro-fit? Thomasmg Plumbing - Systems & Fixtures 12 02-28-2015 09:43 AM
Battery doesn't charge without disconnect / reconnect of shore power WineStream Batteries, Univolts, Converters & Inverters 5 03-26-2013 06:32 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 08:21 PM
