Old 04-24-2021, 07:18 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Waterpump runs intermittently, then stopped
First time out this year, the pump would come on for a fraction of a second about every 10 minutes.
I figured it was a leak, I was dreading searching for it given the concealed areas of the trailer. This happened when I bought it, I found the leak at the water heater.
5 days later, it stopped. Not once it it do it again. Seems like too long for an air issue.
Any thoughts? Thank you.
Ted S. is offline   Reply With Quote
Old 04-24-2021, 07:21 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
System is loosing pressure somewhere if the pump kicks on momentarily every 10 minutes.....
No faucets dripping I assume?
wulfraat is offline   Reply With Quote
Old 04-24-2021, 07:31 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Water heater over pressure valve was leaking and finally reseated? Air in waterlines that was finally expelled?
2019 Ford Expedition Platinum
Old 04-24-2021, 07:33 PM   #4
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
You found a leak. Exactly where was the leak?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
Old 04-24-2021, 08:57 PM   #5
2015 30' FB FC Bunk
It was losing pressure for 5 days, then it stopped...
Old 04-25-2021, 12:28 AM   #6
Long Island , New York
Could have been the pressure relief valve [PRV] at the top of the water heater, as suggested earlier. Mineral deposits can make the PRV's operation flaky and inconsistent IMO. Suggest replacing it with a new one, with the threads properly prepared with Teflon tape.
Please let us know what the old one looks like . . . there are usually some mineral "crust" deposits left behind by the leaking/evaporating water.
Happy Trails.
***** Life is short *****
Let the music lift you up! . . .
OTRA15 is online now   Reply With Quote
Old 04-25-2021, 03:10 PM   #7
1988 32' Excella
Robbinsville , New Jersey
If you were using the pump the whole time could have been a small piece of debris in the pump that finally cleared.
Old 04-25-2021, 04:19 PM   #8
2012 28' International
Prince Edward County , Ontario
Is the water in the hot water tank hot? We had an issue early on where the pump would briefly cycle on and off, usually during the night. I could never find a leak and we subsequently turned the pump off when not using it. I later concluded it could be the water cooling down over the evening (and contracting) leading to a slight drop in pressure causing the pump to cycle. I've since noted the cycling does not happen when the water is cold.
Cyclist is offline   Reply With Quote
Old 04-25-2021, 05:44 PM   #9
2015 30' FB FC Bunk
Interesting, but yes there was water in the HW tank the whole time. I also shut the pump off like you, but I was more concerned there was watering going where it shouldn't be going.
Old 04-25-2021, 05:47 PM   #10
Thank you OP for confirming that the leak stopped. Any chance the PRV had failed per Post #6 and healed itself?
Old 04-25-2021, 06:52 PM   #11
2017 28' International
Jim Falls , Wisconsin
So the pump can also run intermittently if there is air in the line. I had this happen to me. I looked for leaks and found none. We went on a trip. Turned on pump. No problem.
Daquenzer is offline   Reply With Quote
Old 04-26-2021, 11:59 PM   #12
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
The water pump check valve feature could be leaking back. Put city water pressure on it, then close the city water off and wait a few minute and see if the system holds pressure. If you can't see or hear a leak it is probably a check valve, either the water pump or the city fill inlet check valve. Using a full time water filter when filling the fresh water tank or on city water will keep debris out of the check valves.
guskmg
Old 04-27-2021, 05:17 AM   #13
Lily&Me's Avatar
Normal , Illinois
When my water pump has done this, I check that the fresh water tank cap is tight, also the off/on handles in the shower, sink, etc.
If they are not all snug and “off”, enough air gets in to cause the tank to continue to try to pressurize.
Maggie
Find a need and fill it.
Lily&Me is online now   Reply With Quote
Old 04-27-2021, 09:27 PM   #14
2015 30' FB FC Bunk
I don’t believe that is the issue, it was dry. It would be wet if it was failing, correct?
Old 04-27-2021, 09:31 PM   #15
2015 30' FB FC Bunk
guskmg
You may be right. I think we connected to city water at the time the pump went silent. It remained silent as we moved on back to dry camping. We do use a water filter. Thank you, I’m going to look further into this.
Old 04-29-2021, 03:00 AM   #16
It might have been dry when you checked it, but earlier leaks could have left visible mineral deposits, especially around the main stem/shaft of the PRV. With the water pressure off, after opening an inside faucet to relieve all pressure in the water system, flip up the PRV handle, and look for mineral deposits where the shaft exits the main body of the valve. If the water in the heater is hot it is a good idea to wear gloves for this.
Old 04-29-2021, 06:52 AM   #17
Mollysdad's Avatar
Often the pumps do this when they have an internal leak in the diaphragm. Why it stopped is a mystery, but Murphy's corollary tells me that things don't fix themselves, it's just waiting for a bad time to fail.
Old 05-01-2021, 09:35 PM   #18
2015 30' FB FC Bunk
This is golden advice. Thank you.
Old 05-02-2021, 10:23 AM   #19
2019 23' International
Portland , Oregon
This happened to me. Many trips to the dealer to look for the leak. Finally, when the water pump started making terrible noises, they replaced it and both problems are solved.
leedav is offline   Reply With Quote
Old 05-02-2021, 11:12 AM   #20
2019 25' Flying Cloud
Sequim , Washington
I had the same intermittent pump activation on our 2019 25’ RBT FC. After checking all possible valves to be sure they were tight, thoroughly seeking any source of leaking piping, and flushing the hot water tank & confirming the PRV was not the problem, I decided to replace my pump.
It’s an easy job, except getting to the connecting plumbing. I decided to replace the original rigid pipes that were NOT installed as per the manufacturer’s specs in the manual that came with my FC. Specifically, the manual calls for 18” of flexible hose on both intake and output sides of the pump. It also specifies that rigid pipes not be adjacent to the mount, frame or other structures. The Airstream installation used only rigid pipes and these were tight against the wooden mount for the pump (see photo of original installation).
Installing a new pump and replacing rigid pipes with 18” flexible hoses solved the intermittent pumping AND quieted the pump immeasurably. I suspect it also helps the pump longevity to have less vibration against the hard framing material.
Just one of many premature replacement parts (2 hot water circuit boards, refer fan, antenna crank, black tank flush check valve, 2 vent fan gaskets, awning lights, to name a few) I have had to install on my two new Airstreams within the first year or so.
WestieHouse is offline   Reply With Quote
Fan stopped, now Dometic fridge stopped-what now? BWright2016 General Repair Forum 10 08-27-2017 12:14 PM
WaterPump Runs but Doesn't Pump Dreamnair Water Heaters, Filters & Pumps 10 10-10-2015 07:49 AM
Generator runs for 30 minutes to an hour and then shuts off and cannot be restarted Jimcyn Sprinter and B-van Forum 14 05-23-2015 10:11 AM
Generator runs for a few seconds then shuts down Glamper1 Sprinter and B-van Forum 21 12-28-2014 10:30 PM
A/C fan runs then stops cruzaire Land Yacht/Legacy Motorhomes 4 06-21-2014 06:24 AM
