The valves are the second lowest point of the system.
The lowest points is a 90° bend on the line coming from the city water hook up and the line going to the kitchen sink.
I was just going to open the drains on the valves and blow air through the system.
I forgot to add the 3 way valve to pump antifreeze into the system.
Now I am debating if I want hot water at the kitchen sink.
The tankless water heater I was looking at had an inlet for a gas line and cold water and an outlet for hot water.
I was going to mount it in the bathroom.
This is what I’m thinking, I am open to other ideas.
I could still use the tankless water heater and just mount it somewhere else.
Run the cold water and gas line as needed.
I would run the hot water outlet to a T fitting.
From the T fitting, the hot water would go to the sink and the bathroom and I’d just use a fixture like this to control water temperature in the shower.
HowPlum RV/Mobile Home Shower Valve with Hand-Held Shower, Brushed Nickel
https://a.co/d/5czwEBF
The only issue I see is any water heater on the low price side ($160 or less) has a gas adjustment knob.
I’d have to mount it somewhere accessible and interior space is limited and the bathroom was really the only open spot for the water heater.
Would be nice if I could flip a switch for the propane so it could turn on when needed.
Anyone have any recommendations on what to do?
Is hot water at the sink worth this headache?
Thanks.
