Old 06-23-2018, 11:08 AM   #1
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Water Pressure Regulator
I have noted several posts regarding the need for a water regulator. Is this really needed? My manual indicates that the trailer is equipped with a built in regulator.
thewarden is offline   Reply With Quote
Old 06-23-2018, 05:25 PM   #2
2007 22' International CCD
True, but your water hose gets full pressure from the faucet. If the pressure is too high, the hose can bulge or burst. A quality adjustable regulator with a gauge is cheap insurance.
Besides, the internal regulator is built by the lowest bidder...would you trust it to not leak? I don’t.
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
