Old 04-17-2020, 03:48 PM   #1
Billyjchase's Avatar
1967 26' Overlander
Eugene , Oregon
Send a message via Skype™ to Billyjchase
Valtera Sewer System Problem w/'68 Overlander
Dear Forum,
I purchased a Valtera SewerSystem before noticing there was a 2nd small drainage hole a few inches from the blackwater Exit Hook Up.
Has anyone come up with solution to work around this 2nd internal drainage hole so I dont blow black water throughout our all of our lovely '68 Overlanders water lines? (I assume this 2nd smaller drainage is some sort of overflow for gray water?)
Phone "should be attached"
Thanks again for all the help
Billt
Name:	Black Water Drain with 2nd Drain Exit.jpg
Warm Regards,
Billy & Stephie Jo Chase
"The Granny Jo Airstream"
grannyjoairstream@gmail.com
Billyjchase is offline   Reply With Quote
Old 04-17-2020, 04:57 PM   #2
1970 27' Overlander
Liberty , North Carolina
That is the grey water drain there is no grey water tank on your model !
B Wilson is offline   Reply With Quote
Old 04-17-2020, 05:04 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The smaller pipe is the grey water drain.
Back in the day grey water just ran out on the ground. There was no dump valve on the grey water piping.
TG Twinkie is online now   Reply With Quote
Old 04-17-2020, 06:50 PM   #4
2018 25' International
Slidell , Louisiana
With no valve and a straight shot, the jet will generate about 3-6 inches of water column so there is no chance of backing up enough to even get into the shower so you should not have to worry about it. Backwash away!
Brian
Old 04-17-2020, 07:12 PM   #5
1967 26' Overlander
Eugene , Oregon
Thanks Brian!
Well....given I have more time on my hands than Im use to... looks like its going to be a "flushing" weekend !
Thanks and stay healthy (as I talk about messing around with all sort of parasites ! lol)
Billy
Warm Regards,
Valterra 10-Foot Sewer Solution Kit, Macerator Universal Sewer Hose Rpatrick16 On The Road... 16 04-09-2019 11:11 AM
Sewer solution to home sewer-so difficult? lsbrodsky Plumbing - Systems & Fixtures 39 05-05-2018 09:35 PM
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
Sewer Flush System blocked... KIMILI Waste Systems, Tanks & Totes 14 08-31-2004 03:15 PM
