Old 05-21-2023, 09:04 AM   #1
2016 23' International
Los Altos , California
upgrade SeaLevel II to Bluetooth
have a 2016 23FB, was looking to somehow get the tank monitoring system (Sealevel II) bluetooth enabled so I can monitor from phone. Has anybody swamped out the original unit with a bluetooth enabled one? I see they make one, but not sure if it's backward compatible. Hoping not to replace sensors.. just monitor..
jsmall01 is offline   Reply With Quote
Old 05-21-2023, 02:21 PM   #2
2021 30' Globetrotter
East Northport , New York
I replaced mine with the Bluetooth version. Really handy when dumping or filling tanks. Click image for larger version
ID:	432158Click image for larger version
James
Biker is offline   Reply With Quote
Old 05-21-2023, 03:48 PM   #3
TrvlTin
TrvlngTinTin's Avatar
2023 30' Globetrotter
Boulder , Colorado
Originally Posted by Biker View Post
I replaced mine with the Bluetooth version. Really handy when dumping or filling tanks. Attachment 432158Attachment 432159
Have you any information on this product?
https://www.garnetinstruments.com/seelevel-soul/
I’m hoping to be able to entirely ditch ditch the current display? Will I still want Bluetooth?
This I think will tie to your Victron?
TrvlngTinTin is offline   Reply With Quote
Old 05-22-2023, 11:07 PM   #4
was it an easy retrofit? just replace old monitor and keep sensors from old one? Also, I noticed tank monitor. how does that work? did you have to purchase a sensor for that?
Old 02-01-2024, 03:39 PM   #5
steilkurve's Avatar
2020 22' Bambi
2022 25' Globetrotter
St-Laurent , Quebec
Was it a simple swap for you? Anything else you had to change?
I bought the unit from rvupgrades.com. Only $99. However, it does not work at all. I plugged it in and nothing. Doesn't even come on.
Makes me wonder if the unit I got was DOA. Maybe that's why they sell them so cheap. Defective batch?
Any way, did you have to change anything else in the system for it to work?
steilkurve is offline   Reply With Quote
Old 02-03-2024, 07:08 PM   #6
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Answering my question! Turns out the upgrade is not completely plug and play. The order of the wires in the new pigtail don’t match the pigtail from the factory. So, you have to map the sensor wires to different ‘pins’ on the connector. A call into Garnett confirmed that. And I downloaded the wiring diagrams for the P3 unit, the old, and the BTP3 unit, the new. Was easy after that to splice and heat shrink the wires. Now works perfectly. Hope this helps someone.
Old 02-04-2024, 11:45 AM   #7
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
Thanks, something to add to the upgrade list. It appears the only Bluetooth model is the one with an LPG button*? Was it pretty simple to figure out the wire mapping? Otherwise, I will hit you up sometime in the future.
*I suppose I could hook that up to the auto-destruct.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 02-05-2024, 05:21 AM   #8
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Correct. They only have one BT model and it’s got an input for an LPG sensor.
You can just leave it unused.
Mapping the wires wasn’t as easy as I thought it would be but it’s not complicated. The only small hurdle was the wire colors of the new pigtail and the wires coming from the tank didn’t match.
So, I downloaded the wiring diagram of both the old and the new display from Garnett’s website and matched the wires using the position of the wires on the connector. The diagrams tell you what each connector position is (12V, sensor, etc.).
But do hit me up if you encounter a snag!
Old 08-21-2024, 06:07 AM   #9
chris_kelly's Avatar
2021 25' Globetrotter
Somewhere , Texas
Can you post a link of the wiring diagram you used?
I found this one but wanted to confirm it’s the same one you used.
https://www.garnetinstruments.com/wp...diagram-v2.pdf
chris_kelly is offline   Reply With Quote
Old 08-22-2024, 06:59 AM   #10
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
This is the correct diagram. My only word of advice is to not only rely on wire colors as the wire colors of the pigtail from the factory didn't match the diagram in my case. So, I did not match wire colors but connector positions. Makes sense?
Old 08-24-2024, 03:25 PM   #11
Somewhere , Texas
Gotcha.
Do you mind posting a picture of your wiring diagram?
Old 08-24-2024, 04:27 PM   #12
Master Chief BT
BTCMUSN's Avatar
2018 27' International
Tyler , Texas
Gotcha.
Following…this is an upgrade I was wondering about too!
2018 International Signature CCD 27FBQ/Centramatics/Hensley Arrow/16” Michelin XPS RIB/TST-GM TPMS/GM Transparent Camera/Starlink STD
2024 GMC 2500 AT4 DURAMAX/Trailer Tech PKG/Centramatics/Banks Diff Cover/iDash/KATZKIN
WBCCI#11290
US Navy (ret) Master Chief Boiler Technician
BTCMUSN is offline   Reply With Quote
Old 08-25-2024, 07:19 AM   #13
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Gotcha.
I have nothing more in the way of wiring diagram than the official one you posted. The way I did it is with the diagrams in hand, I identified which connector was what on the old and the new unit and tied the wires accordingly. Again, I did not match the colors but rather the functions.
For example, if the first connector on the old monitor is power and connected to the red wire but on the new it is the second connector and brown, I connected the red and brown wires together.
I can unscrew the unit and take a picture of how I matched the wires. Does not guarantee it will be the same in your unit but happy to if it helps. I should be at my AS later today or tomorrow latest.
Old 08-25-2024, 08:21 AM   #14
Somewhere , Texas
Ahh!
That’s the same method I did this morning and got it working.
It’s not at all intuitive based on what Airstream wired to the display.
I attached a picture of how my wiring worked out. The picture with the spade connectors is the final layout.
The original wiring is with the white connector.
ID:	446769   Click image for larger version
Old 08-25-2024, 09:24 AM   #15
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Ahh!
Great to hear. Now that it’s installed, enjoy! I tell myself what a great upgrade this was every time I do tank work!
Old 08-26-2024, 04:28 PM   #16
Somewhere , Texas
Yeah I know! No more pressing my nose against the window to see if we are down to zero.
Old 09-06-2024, 04:51 PM   #17
2024 Interstate 24X
Northern , New Jersey
I just did this upgrade myself on my Interstate 24X. Thanks for the inspiration and information everyone!
mkhllr is offline   Reply With Quote
Upgrade to Bluetooth Coleman Mach AC head unit? STREMON Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-29-2022 05:40 AM
seaLevel monitor system Wycolo LP Gas, Piping, Tanks & Regulators 2 09-27-2015 11:17 AM
Is it ever necessary to calibrate the new SeaLevel Tank Monitoring System? Hibby Waste Systems, Tanks & Totes 11 10-23-2014 05:28 AM
Bluetooth Internet Connection? Lee Davis Full-Timing 10 05-18-2006 11:36 AM
