Old 10-05-2020, 03:57 PM   #1
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
Untimely huge leak (pouring)
2013 Flying Cloud 25RB. Just unhooked and set up. Turned on power & water. Turned on the water heater to electric. Shortly after I smelled some smoke and went outside. Water is pouring from around the low point valves & it is hot water. I shut everything down. Behind the heater I found a yellow capped valve and closed off the hot water about 80%. I cannot fully shut down the hot water. You can hear water going through around the heater (buzzing). Any suggestions or go home?
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 10-05-2020, 04:10 PM   #2
2019 30' International
Pennsylvania , Pennsylvania
Make sure your low point drain valves are completely closed.
Is the hot water coming out both low point drain lines, or just the hot water?
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 10-05-2020, 04:55 PM   #3
Jim J
Jim J's Avatar
2014 30' Flying Cloud
Check this
If the hot water heater input valve was shut off, and the low point drain was open, as you would do when winterizing, There would be no water in the hot water tank and water gushing out of the low point drain causing the symptoms you described.
When you turned the hot water input valve and thought you were closing it, you might have then actually opened it, allowing water to fill the hot water tank but it was then running out the low point drain as it exited the tank.
As prior poster suggested, first check and close the low point drains, there should be one for hot and one for cold. Then make sure the hot water inlet valve is open, the hot water pressure relief valve is closed, and the hot water drain plug is properly tightened.
You should also check the low point and drain valves on the fresh water supply tank. Also check to see if the under kitchen sink water filter is in place if you have one.
Sounds like your coach was left in its "winterized" state.
Jim J is offline   Reply With Quote
Old 10-06-2020, 11:38 AM   #4
PecanMan5's Avatar
Hahira , Georgia
This unit has never been winterized, In fact I can not even find the "H" cutoff valve. I live in the deep South, so it has not been an issue. The water is coming from around the low point valves, not out of them. The system worked fine yesterday. This morning I found leakage under my kitchen sink. Yesterday I hit a couple hard pavement joints on South Carolina construction on I-85. I am thinking something or a tank has busted loose. I notice the bans holding the fresh water tank seems to be bowed. I will post a pic. Any more ideas?
From my Pecan Tree
Old 10-06-2020, 04:00 PM   #5
Jim J
Jim J's Avatar
If you take the interior apart a little you can expose the water heater. Shut off the cold water inlet valve and see if you still have a leak. If yes you have a cold water line leak somewhere, if no open up the inlet valve and see if the leak commences after the tank fills up. If no, it is not in the hot water system. If yes it is either the heater or some part of the plumbing downstream from the heater.
It's hard to see a heater leak because the access is poor. Heaters can leak due to corrosion or a damaged flange fitting. Usually have to remove heater to check it since it is covered with a styrene foam jacket. Takes two people to do that.
Under sink can be drain or water supply. I have had leaks both places. Drain gets jostled by stuff under the sink and comes lose. Water filter leaks if gasket is missing.
Have had fresh water tank leaks at hose connecting drain valve to tank. It comes off if you hit something that moves the tank inside its cover. Could have happened when you hit the bump or bumped the tank on a curb somewhere.
Tanks also leak due to failure at a flange mounting, caused by a combination of overtightening and tank movement. Have to drop the tank to repair it or replace it.
Good luck troubleshooting and correcting your leak.
Petcock drain pouring water GypsyKarma Water Heaters, Filters & Pumps 11 10-10-2016 03:01 PM
Tripping ground fault on shore power.A few days ago it was pouring rain so I went to Coaster Batteries, Univolts, Converters & Inverters 4 03-11-2014 03:55 AM
Filled tank, water pouring out beneath mutcth Fresh Water Systems 33 03-30-2013 02:52 PM
Water pouring out back LJ Green Fresh Water Systems 3 07-05-2012 10:47 AM
Help - Water's pouring in my "New" 1974 sovereign rbenoiti Windows & Screens 16 06-16-2004 07:27 PM
