Old 04-08-2019, 07:01 PM   #1
Carrollton , Texas
Twilight zone
2018 Globetrotter
Hooked up to city water source.
Fresh water tank was dry and drain closed.
Fresh water tank is over flowing.
How can this happen? Any ideas?
JacksonPayne is offline   Reply With Quote
Old 04-08-2019, 10:32 PM   #2
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
Seems to be a fairly common occurrence and happened to us on our first outing when unit was new. Check valve can stick or get a piece of debris stuck in it, possibly from assembly. I turned off city water and ran off fresh water tank via pump to pull tank level back down and this also freed up the stuck valve. I think this is the easiest thing to try first before repairing or replacing the valve.
StuartsDad is offline   Reply With Quote
Old 04-09-2019, 04:36 AM   #3
Sag Harbor , New York
Welcome to the forum!
These search results should lead to some helpful threads/posts:
https://www.google.com/search?q=pump...com&gws_rd=ssl
Disconnect from city water, and turn your pump on/off a number of times while running the water. Chances are good the check valve will clear itself.
If the problem persists, turn on city water again, and do the above a number of times. If no joy, you may have to replace the pump and/or check valve [if a replaceable part -- see other posts via link above].
You must always use a filter in the hose when on city water, AND when filling the water tank.
Good luck,
Peter
Which one is zone 1 and zone 2? Doc Foster Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-23-2017 10:52 PM
Can I run the furnace in one zone and the heat pump in the other zone? Philip Jones Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-15-2017 03:24 PM
Twilight Bungalow 2 :: 1977 Airstream jal4509 Airstream Registry Discussions 0 09-26-2011 08:42 PM
