Old 10-08-2017, 07:23 PM   #1
2016 20' Flying Cloud
Lee , Massachusetts
sink sprayer does not work
The sprayer in our sink is not working, no water. 2016 20 ft FC.
Any ideas?
thanks.
Bobwes is offline   Reply With Quote
Old 10-08-2017, 08:08 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I had the same issue. Went down to Lowes and bought a new one. Easy peasy swap out.
MICHAEL
Old 10-08-2017, 09:08 PM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
What brand faucet do you have?
We have a Moen faucet and it needed a new diverter valve and now the sprayer works perfectly.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 10-08-2017, 09:32 PM   #4
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Are you running water first, then pressing sprayer? I helped someone who was trying to just press the sprayer without water running, so just checking...
Troutboy
Troutboy is offline   Reply With Quote
Old 07-12-2020, 12:41 PM   #5
2017 28' Flying Cloud
Fredericktown , Ohio
No Water Thru Sink Sprayer
I have a 2017 FC, 28', FB with the same problem.
1. Disconnected the sprayer supply line from the line coming form the sink.
2. Turned on the water pump expecting a solid steam to go into my cup.... nothing??
3. Remover the sink (4-8mm socket head screws hold it in place)
4. Removed the faucet:
a. Remove the 3-7mm bolts
b. After the bolts are removed, remove the nut holding the faucet in place.
c. Slide the washer down and out of the way. This will take a little maneuvering.
d. pull the faucet up. You will see 3 lines;
1) Hot water in.
2) Cold Water in
3) Water out to the sprayer
The attached 2 pictures show the water supply from the faucet to the sprayer and the flow restrictor/spring check valve that I found inside. I removed this little valve and everything worked fine again.
Now that you know what I know, just disconnect the sprayer line from the sink supply, remove the flow restrictor/check valve, and reconnect the line. This should take <10 minutes.
Todd Mizer
Ford F-250 6.7L
WBCCI #6826
MMCMRET is offline   Reply With Quote
Kitchen Sink Sprayer & Water Pressure T1NCAN Sinks, Showers & Toilets 14 04-07-2017 06:37 AM
Source for sink sprayer? wigwag General Repair Forum 3 08-07-2014 09:20 PM
64 bath sink sprayer donh1 Sinks, Showers & Toilets 5 01-11-2011 05:11 PM
Safari 27 FB Sink Sprayer keeps breaking Brow324 General Appliance Topics 5 01-22-2010 05:40 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
