Originally Posted by billcruze
I have a 2019 classic 33fb with a leaking shower drain. It runs water out from under the pan around the toilet. It has done this in the past and then stops but it is doing it again. I have filled the pan with water to see if it's leaking around the seal and it doesn't appear to be. When I run water directly in the drain is when it leaks. Has anyone had this problem and how did you fix it?
I’m not sure if my problem is the same as yours…the shower would
occasionally leak next to the toilet. The factory service center identified some missing sealant between shower glass and aluminum shell. Have you made sure the seems are all fully sealed?
