Old 05-09-2020, 06:17 PM   #1
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Shower drain Hepvo trap
2015 Classic, shower is draining kind of slow, and wanted to remove the Hepvo waterless trap and clean the hair out of it, but want to find out if anyone has performed this task? Looks like the Hepvo was assembled with some healthy doses of plumbers compound, the hardening kind. Not a lot of room to work in the space either, so I'm wondering how someone went about this before I tackle it. The bathroom sink is apart not to replace the sink stopper.
rbs is offline   Reply With Quote
Old 05-09-2020, 06:23 PM   #2
Long Island , New York
You may have done this search already, but FYI and FWIW here are the mentions of that drain valve, scattered throughout Airforums:
https://www.google.com/search?q=Hepv...=airforums.com
I seem to recall some mentions of taking some out.
Good luck,
Peter
FYI
FWIW
Old 05-09-2020, 06:30 PM   #3
1966 22' Safari
Fredericksburg , Texas
Sounds like you only have a couple of choices. You may try a 1/2Ē water hose with the brass end cut off and see if you can shoot some water with pressure to blow out the Hepvo. If you try and run a plumberís snake in there youíll ruin the duck bilked flapper in the Hepvo. Or, try with effort to unscrew it. If itís stiff plumberís putty, you may try torquing it toward tight to break the putty bond, then unscrew. Sorry, havenít heard of this issue. Good luck
Bubba L is offline   Reply With Quote
Old 05-09-2020, 07:55 PM   #4
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
I replaced the bath sink Hepco in my 2016 Classic last year - it was clogged with soap scum, probably from using minimal water to wash our hands. Luckily our shower drain still runs ok, probably because showering uses more water.
A repair technician at Airstream told me that the shower Hepvo is much tougher to replace and that soaking it with white vinegar can disolve the soap scum to make it run better without replacing it. I'll definitely try that if the shower drain ever slows down. I might even decide to treat all our Hepvos with white vinegar annually (or more frequently) to keep them running.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 05-10-2020, 03:10 AM   #5
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Good luck,
Peter
FYI
FWIW
thank you for your help and best wishes
Old 05-10-2020, 01:17 PM   #6
2019 25' International
Washington , Washington, D.C.
When you get the hair all cleaned out, I recommend you keep a drain protector in the drain to prevent hair from going down. Mine looks like this. I have one for home as well and they work great.
PatLee is offline   Reply With Quote
Old 05-10-2020, 01:27 PM   #7
Not sure that will fit in rbs’s drain.
Will that drain protector fit in your drain? I thought the Hepvo drain assembly was right up level with the shower floor +/- ?
Peter
Old 05-10-2020, 02:56 PM   #8
2015 30' International
FREDERICK , Maryland
We used a little tool called the Drain Weasel to clean out our shower drain in 2016 International.
Once you clean out the hair, use some sort of shower drain cover - we use something like this - https://www.amazon.com/OXO-Grips-Cle...n%2C147&sr=1-7
Doc Foster is offline   Reply With Quote
Old 05-10-2020, 04:06 PM   #9
Bingo!
Easier to clean hair off that kind of filter IMO.
Peter
Old 05-10-2020, 09:11 PM   #10
StuartsDad's Avatar
2018 28' Flying Cloud
Fairfield , California
Once you get it cleared, consider investing in a TubShroom. Fits perfectly in our shower drain and possibly the best thing I bought for our AS under $20. I clean it off after a couple of showers and glad all that hair is not going down the drain.
StuartsDad is offline   Reply With Quote
Old 05-11-2020, 08:14 AM   #11
1986 31' Sovereign
Miami , Florida
Ditto on the Tubshroom. Simple, effective design and cheap.
new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 05-11-2020, 11:23 AM   #12
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Hepvo recommends high air pressure, so I'll go with the vinegar then rig up something put some pressure into it, then check for success. Thought I would post a picture of the trap and it's tight location. Picture quality not the best, but it would be a challenge, more difficult by the compound used on the joints, hopeful for air pressure/vinegar. Also ordered a Tubshroom. Replacing the bath sink stopper, the OEM disintegrated. Got the time, might as well make things better
Thanks for the help always appreciated
Old 05-11-2020, 06:44 PM   #13
Thanks for the update . . . good luck!
Peter
Old 05-12-2020, 10:02 PM   #14
1962 22' Safari
2016 30' Classic
Images: 41
I had to use a pipe wrench to undo the couplers on the Hepvo under the bath sink due to the pipe sealer Airstream used. No way hand strength was enough to undo them. I have no idea how you'd get a pipe wrench on that shower Hepvo given the right space around it.
Joe
WBCCI/VAC #6768
Old 05-13-2020, 06:03 AM   #15
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
there is absolutely no room to operate a pipe wrench, a strap style wrench would be the only option. In my opinion a person would need to undue the connection at the gray tank and work backwards to remove the waterless trap, in a very awkward body position working in very tight quarters. The waterless trap in the bath sink was a carbon copy of your experience, and I ended up replacing the entire assembly because of damage to the compression nutt on the elbow. Pray you never have to replace the drain assembly in the shower
Old 05-18-2020, 05:03 AM   #16
. . . Pray you never have to replace the drain assembly in the shower
Leak in shower drain assembly/p-trap - 2012 16' Bambi Sport debrunyon Sinks, Showers & Toilets 2 10-28-2019 07:37 AM
HepvO Self Sealing Gray Valve Pams72 Waste Systems, Tanks & Totes 3 02-15-2014 02:40 PM
Shower drain have a P-trap? guntertl Plumbing - Systems & Fixtures 2 01-08-2012 08:27 PM
HEPvO waterless valve hampstead38 Sinks, Showers & Toilets 3 09-12-2010 07:23 PM
Frozen shower drain trap 3 Dog Nite Winter Living 4 01-20-2009 01:51 PM
