12-20-2015, 11:46 AM
benicia
Should I use a toilet snake to clear the clog? Need advice ASAP.
I have tried a toilet wand that has four ports at the end of the wand that spins at a rapid rate. I shoved it down the toilet and turned it on full blast hoping to push the clog down into the tank. The water just backed up close to the flush valve so the pressure wasn't enough to push the clog down.
Not sure what else to do but to snake the toilet. Has anyone down this in an RV toilet? Is there anything else I should try before the snake? I can't reach the clog to pull it up and out. The blank tank sensor reads empty so the clog, I believe, is up high and not in the blank tank yet.
I have a 2011 28' FC. Thanks in advance.
12-20-2015, 11:49 AM
Biloxi
, Mississippi
I just did this yesterday to all my traps. Drains are much clearer now. So far no issues with the head drain.
MICHAEL
12-20-2015, 12:31 PM
benicia
Going to snake it now. Thanks for your response AWCHIEF.
12-20-2015, 12:33 PM
1993 34' Excella
Estancia
, New Mexico
How about a plunger?
12-20-2015, 01:49 PM
Mantua
, Ohio
When I bought this trailer the black tank as a problem, I did as has been suggested, I use a snake like thing and also a bathroom plunger. It took several usages to get all flowing right. I also used the plunger in the tub drain and it helped a lot because the gray tank also drained slowly. Good luck, it may take a few tries especially with the plunger.
12-20-2015, 03:00 PM
2001 34' Limited
Tucson
So I'm confused.... I'm by no means an expert on RV plumbing, BUT....Question#1 is Do you actually have some form of plumbing pipes attached to your Toilet? Every RV toilet I've ever seen is mounted directly on top of the black tank.
So, if you've filled up the tank to the flush valve and still nothing coming out when you pull the black tank valve, then one of two things could be happening. Faulty black tank valve.... or a blockage in the passageway right before the valve. (I'm going to guess your not in freezing weather. Otherwise a third issue could be frozen "water" in the bottom of the black tank. )
Forget what the black tank sensor says, they are notoriously useless. Also, a plunger is likely to do nothing more than give you a good workout.
I dont know how/if a snake would work being that the toilet sits atop the black tank and there is no pipe for the snake to "follow" , unless you were actually lucky enough to get the end down to the outlet port. ( unless you're talking about feeding the snake "upriver" from the outlet.... in which case you're a brave man!
A bit more info may be required to complete this troubleshooting.....
Had the trailer been in regular service when this clog presented itself? Or is it freshly out of storage? have you had freezing temps that may have froze the contents of the tank? Give us some details & lets see if we can fix the problem.....
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
12-20-2015, 03:27 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I, too, am a little confused. I don't see how or where to use a plumbing snake in an RV toilet. I just don't see where it would do any good to put it down the bowl. Putting it in from the drain valve end would be playing with fire. If you did clear the clog, you would have a monumental mess in your lap.
What you are describing sounds like it could be "black hills syndrome". This occurs when the black tank valve is left open while camping. Solid waste dries up and becomes like concrete in the black tank.
If this is the case, there is only one possible solution. Put in some toilet chemicals, fill the black tank about one quarter full, add a couple of bags of ice, and go for a ride with the trailer. Made some sudden stops to get everything stirred up.
Try dumping again. If you still get nothing, try some more ice and take another ride. Hopefully, you can get it cleared this way.
In extreme cases, "black hills syndrome" can require replacement of the black tank.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
12-20-2015, 04:24 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
I agree with Moosetags, to drive around long enough to breakup the solids. If your tank is too full to add ice, you might have to get something rigid, like a small diameter pipe, down through the toilet and try to stir the pot a little bit before going for the ride.
I purchased a trailer with the "black mountain syndrome", the tank barely drained and the valve was difficult to close completely. I used the "Geo Method" (detergent, water softener, and bleach) to break up the solids that were creating the problems. I can actually see clean plastic at the bottom of the tank now and the valve works smoothly.
Alan
12-20-2015, 04:29 PM
2002 19' Bambi
Lafayette
We had our black water tank plug up with essentially nothing coming out of it even with the drain valve open. This happened about 8 or 9 years after buying the trailer new and we had always regularly drained the tank and back-flushed it. Not being brave, but desperate, I used a snake from the downstream end. That sort of worked and the tank drained slowly afterwards before stopping up again.
I won't go into how I got it out (ugh!), but the blockage was from the round disk of plastic tank material which had been cut out of the tank when the drain was installed. The managers of the RV park where we often stay said they had the same thing with their fifth wheel and a trailer and were happy to hear that it could also happen in an Airstream.
Tim
12-20-2015, 05:05 PM
1988 32' Excella
Ojai
We had this same thing happen to us and this is the tool of champions...
http://www.amazon.com/Valterra-F02-4.../dp/B008O9DV78
Let the tank trickle drain to give the tank some head room. If this won't happen then it will take one person monitoring the toilet bowl level (we had to do this). Make sure and use a large volume hose to get a good burp started with the Flush King valve closed. Run the water for a few seconds then shut if off. If the clear section of the tool fills you have dislodged the offending material. Once you have drained the tank use the tool to back fill the tank and then drain. Repeat this until the water comes out clear. If you use this at every dump and flush the tank you wont need the Chocolate Milkshake maker but one a year or so. Please don't pull a Chevy Chase, but if you do post a video!
GL
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 300k+ (The Beast)
12-20-2015, 06:52 PM
1974 Argosy 20
Kooskia
, Idaho
The ice cubes in the tank idea was pretty well debunked in this You Tube video.
12-21-2015, 10:27 AM
Taos
, New Mexico
RV plumbing is typically PVC pipe that looks an awful lot like the drain pipes in your, at least my, house. Using a snake should be okay. Just be careful about what happens when the snake gets to the destination in the black or grey water tanks because you sure don't want to punch a hole in either of those. Your toilet must be different from mine because mine has a straight pipe into the black tank, no curve or trap at all.
12-21-2015, 04:27 PM
2009 27' FB Classic
Sioux Falls
, South Dakota
My black water tank occasionally doesn't drain properly. The drain valve becomes clogged with toilet paper and other solids. I use a *macerating pump. The pump creates a vacuum and with a full tank of water I am always able to clear the clog. If you have time add some ridex to the tank and in the future be very stingy with the toilet paper (single ply only). Keep up with the chemicals; they help dissolve the t'paper and break up the solids. Only have the black water tank valve open when draining the tank never leave it open when camping. Good Luck..
Snaking up stream will work so be prepared to handle the 5-10gal of black water. Do the snaking at the dump station.
12-21-2015, 05:22 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Shaking & Waves
If your RV is parked and you have an electric jack, you can create waves in both tanks simply by retracting the stabilizer jacks and rocking the RV back and forth by raising and lowering the jack. These waves might be gentle - but they are moving 30-50 gallons of fluid in the tanks. If you want to hook up you can simply shift from drive to reverse and back - moving the trailer a few feet each way then applying the brakes firmly to shake the tank "stuff" loose.
Got to admit that Tuco's "tool of champions" should be really effective too - and give you feedback about how much stuff is moving out.
Paula
12-21-2015, 06:30 PM
Walnut Creek
Camera
The folks where we store our AS use a camera to see where black tank problems are located. Then they use a high pressure wand with multiple nozzle flows to break up the problem areas. Looked like they were having fun this afternoon. Pat
12-21-2015, 07:06 PM
Sag Harbor
, New York
Could you be more specific about the problem and what you actually can see? Your post does not make sense to me.
Isn't your toilet sitting directly on top of the black water tank? If so, how could you be "hoping to push the clog down into the tank?" Could you actually see the clog? Where -- in the bottom of the toilet?
You say, "I can't reach the clog to pull it up and out." Can you see the clog? Where? If it is "up high" where do you think it is? What is between the bottom of the toilet and the black water tank?
Does your owners manual provide a schematic of the waste plumbing which shows what is between the toilet and the black water tank?
Please provide more details, and the results of the steps you have taken already.
12-21-2015, 09:32 PM
1980 24' Caravelle
corpus christi
One time I would not want to be looking over their shoulder as they work.
12-21-2015, 10:00 PM
TinGrin
2017 Basecamp
Tucson
Always must be carefu about punching go a hole in the tank with a snake. My advice (retired mobile rv tech) is do not snake it. You can use a long pice of pex pipe with a wrap of duct tape on the end- keeps the back flush from hitting your face- work it slowly around- if it is a clog this can take care of it. If the plastic spinoff from the tank install is the problem, no snake will help. Finally, the deep soak with some Dawn liquid soap can help loosen the mess to drain. Bad problem all the way around- best to be aware to avoid by not leaving drain open al the time.
12-21-2015, 10:32 PM
benicia
Thanks for the responses everyone.
As I said earlier, I used a toilet wand with spinning jets. The water level in the toilet rose up to just below the flush valve and wouldn't go down. I decided to attack it the next day with a snake. I was pleasantly surprised to discover the water level had seeped through the solid material, exposing the clog. I used a two foot long tool with pincers at the end to pull up and out all the wadded up toilet paper and the nastiness. It was gross. However, I was able to unclog the toilet.
The clog was stuck at the neck of the black tank. The only thing I can think of as the cause is I was too frugal with flushing since I was boondocking. Also, temps dropped to 29 degrees F which may have frozen the nasty stuff that didn't get enough water to drop into the black tank. Anyway, I am glad the ordeal is over.
12-22-2015, 04:20 AM
Sag Harbor
, New York
Thanks for the details. Difficult to think about while I am enjoying my morning coffee and toast, however!
So is there a horizontal run of waste pipe under the toilet, leading to the black tank where the clog happened? If so, is there also a 90 elbow sending the waste down into the BW tank? It would be helpful to know these details for future reference, as my toilet is directly over the BW tank.
Thanks, glad it all "came out" OK!
Peter
