10-20-2017, 08:40 PM
#61
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
This thread!
"RV" toilet paper is a scam and you use twice as much to avoid perforating it. Ewwww. Velvety, thick, Double ply, fragrant, home-bathroom kind for me. And I often follow up with oversized wet wipes. Guess where they go...right in the black tank too.
Never a problem. It all dissolves. It's water, bacteria, paper, and waste, mixing up in a slurry of effluent. That flushes right out.
As for smells from the black tank from using it...if there's a smell, something is wrong. The water and bowl seal isolate the tank. So if you smell something, then there is a broken vent to the roof emitting gasses into the coach, or no water/seal in your bowl.
10-20-2017, 09:05 PM
#62
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Lots of things marketed to RVers are scams. Toilet paper is only one of many things that is overpriced for what you get when you tack an "RV" label on it.
Personally, I don't care if it's RV toilet paper or regular, as long as it either dissolves before it gets to the macerator pump or else the pump can chew it up into tiny bits without getting jammed up. And as long as I can buy more before I run out. I intend to try using Charmin Ultra Soft— as suggested earlier in this thread— during my next outing, but putting wet wipes in the black tank ain't happening in MY Airstream.
10-20-2017, 09:19 PM
#63
The Aluminum Tent 3
Park City
, Utah
Originally Posted by Protagonist
And as long as I can buy more before I run out..
That is my biggest concern regarding this whole topic!
I used sandwich baggies to dispose of them at first, till I realized they were made of paper (the kind I use were even marked 'septic safe' lol) and not much thicker than luxurious home toilet paper. I have found they break down and drain out fine...but admittedly they probably are pushing the limits of "safe" toilet paper practices. I'd rethink it if I had a macerator pump...
10-20-2017, 10:33 PM
#64
Overland Adventurer
2009 34' Panamerica
Telluride
What?
Is this an issue?
We've got 4 kids and 2 adults living full time in our AS. We crap as much as the next family....
We flush down at least a Costco size pallet of tp a week..... Pull the plug and it magically goes away, simple as that!
Sometimes a young one will look down the hole, only to find a lonely corn or peanut on the floor of the tank..... That's some entertaining stuff! I never gave thought to issues like this as a reality ��
10-21-2017, 02:14 AM
#65
From All Over
Originally Posted by AtomicNo13
What?
Is this an issue?
For anyone who discharges their waste tanks through a slinky, no, it's not an issue. Normally. Unless there are too many solids and not enough water, and something solid only drains as far as the dump valve and blocks it from closing all the way.
For those of us with Interstates built after 2009 that discharge through a macerator pump, it IS an issue. Removing a clogged macerator pump to unclog it is a truly nasty undertaking that is NOT made better by the fact that the fecal waste you get drenched with  when the pump comes off is your own.
Although I do recall a time, at Lincoln Parish Park— I think— at one of the now-defunct "Two Weeks From Everywhere" AirForums rallies, that something that came out of a trailer's waste tanks clogged the campground sewer lines. Those of us located downstream of the clog were fine. Those upstream of the clog found their campsites awash in nasty-smelling brown water that backed up to their sewer connections and overflowed. The family that caused the clog was made to feel very unwelcome by those whose campsites became unsanitary cesspools. So please remember that even if undissolved solids flush just fine through your slinky, they may not make it all the way through the sewer lines and may become someone else's problem.
10-21-2017, 04:04 AM
#66
1984 27' Airstream 270
Scotia
, New York
That is why I bring lots of beer, never a problem with too many solids, especially if it is Mexican beer
From all the comments on TP type & hype, I think I will try the old school 1000 sheet Scott brand that we use in the house.
I am tired of the endless buying of the RV stuff. I swear the ladies go through a 4 pack of that in a day or two!
For me, on my own, a roll will last a week or longer.
10-21-2017, 04:19 AM
#67
From All Over
Well, they do have to wipe for #1 as well as for #2, unlike us guys…
10-21-2017, 05:59 AM
#68
Scotia
, New York
Yes but the math still does not add up:
1 + 2 should not equal 4 rolls in 2 days?
Maybe it is that new math?
10-21-2017, 06:23 AM
#69
From All Over
Just accept it as a given, and let it go. You can't ask them to use less and expect them to be happy with the idea.
10-21-2017, 07:31 AM
#70
1996 25' Excella
Tillsonburg
, Ontario
What great entertaining reading on a Saturday Morning!
Macerator pumps need TLC; the rest of us can even use paper towels...not advisable but possible...My grandson proved that
JCW
10-21-2017, 08:48 AM
#71
2016 Interstate Lounge Ext
Green Cove Springs
Originally Posted by CRH
Where do you go #2?
If you're in campgrounds, their toilets work fine.
If one is boondocking with no facilities (not even pit toilets) nearby, I move that the #1-only-in-the-RV solution becomes a bit more problematic. Could one say it plops?
10-21-2017, 10:31 AM
#72
From All Over
You apparently missed my point a few posts ago about not clogging the campground's sewer lines with something that comes out of your slinky. Your grandson was lucky that time…
10-21-2017, 11:43 AM
#73
2012 19' International
Southeastern MI
, Michigan
I can't believe this thread is "still going" (pun intended)
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
10-21-2017, 01:00 PM
#74
Long Island
, New York
Never underestimate the power of matters fecal to give a thread the runs . . .
Remember the Fork Fell Into Black Tank thread?
[click on arrow in quote to go there]
Originally Posted by lsbrodsky
This is not going to be helpful to the OP, but I gotta say that my best entertainment comes from reading posts on this Forum! I make it a point to learn from every post possible!
Larry
10-21-2017, 01:04 PM
#75
2013 31' Classic
billings
, Montana
I use the best toilet paper and never had any problems.....
10-21-2017, 02:05 PM
#76
Overland Adventurer
2009 34' Panamerica
Telluride
Egads.... I just threw up in my mouth!
10-21-2017, 02:10 PM
#77
Overland Adventurer
2009 34' Panamerica
Telluride
Isn't the job of the macerator to turn everything into a poo milkshake then pump it out?
Ifthis is the case, no solids should matter as long as there is sufficient liquid content to blend it all up?
10-21-2017, 02:40 PM
#78
Long Island
, New York
Paper towels and baby wipes are really asking for trouble in a macerator IMO, which are simply not designed to shred these materials IMO.
Do some industrial and residential sewer pump out macerators handle this kind of material? Yes, but the macerators in an RV are down-sized and rated for a very specific use.
Just read the dozens [hundreds?] of "macerator problem" posts for further details:
https://www.google.com/search?q=mace...=airforums.com
[There are 19 pages of search results, on this AF site alone. A general Google search on the Internet would probably take weeks to sort out, and wipe clean.]
And the stuff runs on . . .
10-21-2017, 05:28 PM
#79
2017 23' Flying Cloud
Parker
I agree with Peter, I’m in the wastewater business. Baby wipe are tearing up large industrial type pumps.
Here’s an entertaining test video
Troutboy
10-22-2017, 03:35 AM
#80
Scotia
, New York
For Chits & Giggles I did that test on my Home TP, Scott 1000 sheet, (Otherwise known as 400 grit sandpaper)
The Scott stuff was mostly dissolved after an hour, at least good enough for the RV tank, so I will switch to it for RV use.
I am also testing Bounty 2ply paper towels and after a hour there is no signs of breaking down. I will let it go longer to if anything happens (at least until I get the evil eye from the other half)
