Old 08-14-2019, 11:25 AM   #1
2017 22' Sport
Painesville , OH
Rumbling in the lines
Hi! Bought a 2017 22FB in May and have been using it every other weekend since. Last two outings we fill up water at home and dry camp like usual. Except now when we wash hands we hear a low rumbling and shaking in the plumbing. If you flush the toilet then it stops. Sooooo weird. Oh and the last time when we turned on the pump after we parked, it took a few minutes to build pressure and shut off. Any suggestions would be greatly appreciated.
Thanks!
Jen (ChromeHome)
bent4bubbles is offline   Reply With Quote
Old 08-14-2019, 12:00 PM   #2
2013 20' Flying Cloud
Westerly , Rhode Island
Could be lots of things, so here's a guess. The top of the strainer (right before the pump), is not tight or there is an issue with the gasket, water is draining back to the fresh water tank and air is getting in the strainer and line. When you wash your hands there is not enough flow to get rid of all the air, so it shakes the plumbing. When you flush the flow is much higher and clears the strainer of air.
smithcreek is offline   Reply With Quote
Squirrel Eating Gas Lines! lbrodsky LP Gas, Piping, Tanks & Regulators 8 07-06-2002 11:03 AM
Replacing plumbing lines GTracer Fresh Water Systems 1 06-30-2002 12:02 AM
Water lines in '73 Overlander Bryan Fresh Water Systems 8 06-06-2002 12:42 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 02:06 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 07:04 AM
