Old 06-02-2019, 06:13 PM   #1
1967 24' Tradewind
Barnardsville , North Carolina
Rookie mistake with septic
I recently acquired a 24 ft 1967 Tradewind. It was hooked up to septic system and is now backed up and not draining. I didn’t even know there was a specific way to use a camper toilet and protocol for how to flush it all or if holding tank. It seems clogged. Can you plunge a camper toilet just as you would one in house?
Thanks for any guidance,
The rookie
Hbelle is offline   Reply With Quote
Old 06-02-2019, 06:22 PM   #2
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Do you mean it was hooked up for a long time before you got it, or that you hooked it up and it won’t drain? Are you sure the tank is full? Gate valve fully opened?
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Old 06-02-2019, 06:50 PM   #3
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
The best procedure is to let the black tank fill before draining. If you leave the waste valve open all the time the liquid will drain away leaving the solids behind building the dreaded ‘poo’ pyramid.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 06-02-2019, 07:23 PM   #4
Sag Harbor , New York
The rookie
Welcome to the forum!
Please post more details about how this toilet has been used, and whether the trailer has been towed recently to shake up the tank's contents. What does the previous owner advise?
RV toilets are totally different than household systems. You cannot plunge them, assuming yours is a typical RV setup. Photos would help to let everyone know what your toilet is, and the discharge valve situation.
Too many variables at this point, so you may get a bewildering assortment of comments IMO.
Good luck,
Peter
PS -- This article may help you get your feet on the ground terlit-wise:
https://blog.campingworld.com/rv-bas...-holding-tank/
Old 06-03-2019, 11:21 AM   #5
Kingsland , Texas
Holding tanks
Add 2 cups of water softener powder and 2 cups of laundry powder. Fill with warm water as much as you can. Let set as long as you can and drain. If really as bad as it sounds you may have to repeat. I pulled the same stupid stunt and it took me a week to get mine clean. If and when you get it clean fill with water and a gallon of bleach. Let stand a few days and rinse. Add the powders after draining each time. It keeps the solids from sticking to the tank
palerider is offline   Reply With Quote
Old 06-03-2019, 12:15 PM   #6
1981 31' Excella II
New Market , Alabama
Sometimes you need a garden hose through the toilet to get stuff moving.
Perry
Black water tank with septic system rfield54 Waste Systems, Tanks & Totes 5 06-02-2021 07:13 PM
Rookie mistake - haste makes waste Tomfeury Waste Systems, Tanks & Totes 10 09-05-2018 11:24 AM
Rookie mistake--battery cover gone with the wind Bourbonshot 1959-69 Tradewind 3 09-23-2016 08:58 PM
Rookie Mistake - Am I in trouble? Heat Pump Issue! jonthms 2011 - 2015 International 34 04-04-2016 05:54 PM
Rookie mistake. Tell me I haven't screwed up ! AirEPotter Full-Timing, Winter Living & Workamping 27 01-10-2011 10:03 PM
