Old 05-09-2021, 05:32 PM   #1
1975 31' Sovereign
brewster , New York
Replacing shower head
Any suggestions for replacing the hand held shower head on my 1975 Soverign?Im not sure if it is standard shower connection? Also I tend to take”navy showers” (turning on water only minimally. Thank you
blumob is offline   Reply With Quote
Old 05-09-2021, 05:44 PM   #2
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
I replaced the stock shower head in my Airstream with an Oxygenics unit. They make several models, but I chose the Body Spa. It works well. I don't know if it would fit your shower hose or not.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 05-09-2021, 07:11 PM   #3
Condoluminum's Avatar
2016 25' Flying Cloud
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Oxygenics works well but are large/heavy if you have flimsy showerhead holder.. Any std water-saving unit should fit the 1/2" threads.. We added an inline shutoff valve to let water dribble (and stay warm while running a little) for navy-style showers) Example: https://www.amazon.com/Energy-Saving...f_B00EA06Z3M/?
Condoluminum
Condoluminum is offline   Reply With Quote
Old 05-09-2021, 08:23 PM   #4
2000 25' Excella
Northern , California
We also like the Oxygenics shower head, and don't find it unreasonably heavy or awkward. It mixes air with the water flow, and gives at least the illusion of robust water flow, while low water flow is a a common complaint with many shower heads.
Kamiak is offline   Reply With Quote
Old 05-10-2021, 08:00 AM   #5
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
X2, - Brad.
SuperTrouper is offline   Reply With Quote
Old 05-10-2021, 09:12 AM   #6
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Another vote for Oxygenics showerhead. It is a bit heavier than the stock one but we have not had any issues as a result. You could just take it out of the holder, let it dangle, and wrap a small towel around it so it does not damage the shower wall while underway.
thewarden is offline   Reply With Quote
Old 05-10-2021, 09:29 AM   #7
Dennis C's Avatar
I don't think the Oxygenics Body Spa shower head weighs much more than the Delta shower head that came from the Airstream factory. The Oxygenics unit came with a shutoff valve, and it was easy to adapt to the factory mount on the shower wall.
Name:	Oxygenics Body Spa.jpg
Dennis
Old 05-10-2021, 10:47 AM   #8
1975 31' Sovereign
brewster , New York
Thank you all. I had the bathroom switched from another Airstream (not sure of the year) either way the oxygenics should be a real improvement.
Old 05-10-2021, 10:59 AM   #9
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
I do like the Oxygenics. The only thing you loose using the Oxygenics is a few degrees of angle. ...you can't point it up/out as much as the
Delta. Not an issue if your are 5'9 & shorter. If you are taller and or shower has a lower ceiling, it could present an inconvenience.
- Stewart
s1000pre is offline   Reply With Quote
Old 05-10-2021, 11:06 AM   #10
Dennis C's Avatar
I'm 6'3", and I agree with your assessment! The shower in my 23FB is essentially a sitting shower for me, so this hasn't been an issue. I had to sit in the shower with the factory Delta shower head also.
Dennis
Replacing Shower Head DoggerStream Sinks, Showers & Toilets 11 03-26-2014 10:12 PM
Replacing the Head piece slk Awnings 2 06-24-2009 06:23 AM
Replacing Shower Head Holder Safari-Rick Sinks, Showers & Toilets 3 10-26-2008 08:56 AM
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:12 PM
