Old 05-08-2018, 04:28 PM   #1
2013 20' Flying Cloud
2017 28' Tommy Bahama
Holmen , Wisconsin
Quality not so good.
Hi, I have had so many water leak issues with the 27' TB I had to share this photo of the back of the shower valve. Duck-tape and spare wood! No kidding. Thats from the factory.
jmchenry is offline   Reply With Quote
Old 05-08-2018, 05:59 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I suppose you should be glad it isn't chewing gum and cookie dough!
Sorry you're having trouble!
Old 06-20-2018, 02:05 PM   #3
2012 25' FB Flying Cloud
albany , Georgia
I had to remove out toilet from the floor because it was not secure and discovered that the idiot that cut the hole in the plywood floor, made it way too big. He squirted some liquid nails where the wood should have been and screwed the unit down. This is a 2012 unit, found the issue a few years ago.
I was furious, when considering that the cost of an Airstream is way up there, these things should not happen.
jmpgino is offline   Reply With Quote
Old 06-20-2018, 02:31 PM   #4
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
Here I am doing Warranty Work outside Alpine, Wyoming at the Ace Hardware Shop. The hot/cold water valve hardware detached from behind the shower wall. I also needed to secure a Ptek clamp on a water line behind the shower as it was not secure.
How else will you discover the secrets behind the... wall?
Ace Hardware let me borrow their tool to secure the clamp.
The hardware was attached to a piece of wood that was not attached to anything. The 2006 Safari was less than one year old. This was the first time I was able to be in the shower... to repair it.
Do not ask me how hot it was to understand how to disassemble my Safari to then, figure out what I needed to do. Never had another problem with the shower until selling it in 2014. Upgraded... of course.
It is secure now.
ID:	314630   Click image for larger version
Human Bean
Ray Eklund is offline   Reply With Quote
Old 06-20-2018, 02:40 PM   #5
2007 22' International CCD
A PEX ring squeezer and a stack of the stainless steel PEX rings are also part of the AS "Go-To tool and spares kit".
The kit includes:
All manner of fuses
Spare screws
Gaskets, washers, and O-rings
Pop Rivets and tool
Blue tape
Duct Tape
Caulk
Wire
Crimp lugs and ratchet tool
Common hand tools
Metric and fractional size wrenches and sockets
Spare toilet valve assembly
PEX tubing pieces in both colors
PEX fittings and spare valve
Teflon tape for water (white)
Teflon tape for Propane (yellow)
And at least one of any weird tool, bulb, smallish spare part, or whatever I have ever needed to make any repair or modification on the Airstream...
Justin Case is a good buddy of mine...
Old 06-20-2018, 02:47 PM   #6
Ray Eklund's Avatar
rmkrum.... you left out... chainsaw. Needed when in New Mexico while camping in the Gila National Forest. When the wind blows in the Gila... you have to chainsaw your way back out.
Human Bean
Old 06-20-2018, 03:00 PM   #7
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Wow!
I'm a plumber and don't have words for that, not that I can say here anyway.
So is every TB delivered that way? other models with the same valve? makes me wonder.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 06-20-2018, 04:50 PM   #8
Martee's Avatar
2017 25' Flying Cloud
Waco , Texas
Either done at the AS factory, or by the dealer prior to delivery. AS dealers will try to fix or repair minor problems prior to delivery to the customer.
I recently tore my 2018 Flying Cloud 25FBT apart to check quality and looked at the plumbing system, and also replace the mixing valve on my Atwood hot water Heater.
Everything looked great and properly fitted, but it is the typical "lite weight" RV plumbing system used industry wide. Nothing special by Airstream....
Martee is offline   Reply With Quote
Good Sam Roadside Assisstance-Good or not so good? flyingfishy On The Road... 27 05-16-2017 01:37 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Airstream "tradewind"1961 vintage quality in good condition--florida eBay Watch Airstreams on eBay 0 12-19-2012 08:10 PM
will a good quality residential range survive in an Airstream? Darkspeed Stoves, Ovens & Microwaves 17 07-08-2011 02:21 PM
