Old 03-21-2021, 03:28 PM   #1
2015 23' International
Stillwater , Oklahoma
putty for new drain vavle
After much work and going through the closest floor I have managed to pull out the white plastic drain valve from my 23 ft, 2015 INTERNATIONAL. The old one looks like it has some blue putty-like substance around the threads that go into the piece of hose. Any suggestions what this blue putty-like is, should I use the same for new plastic plug or just put some plumber's putty around opening?
slocy is offline   Reply With Quote
Plumber's putty or glue? cathy624 Sinks, Showers & Toilets 13 11-29-2010 05:49 PM
Name that putty....or whatever its called.... mikvw Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 10-26-2009 02:38 PM
epoxy putty leak fix? Chuck Fresh Water Systems 20 04-22-2009 09:21 PM
butyl putty tape on the roof bacevedo Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 02-22-2009 05:09 PM
Plumbers Putty Buttercup Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 08-10-2005 02:28 PM
