Old 05-25-2020, 09:58 PM   #1
2017 28' International
Baileys Harbor , Wisconsin
Pump problem
The water pump, pumps water. It will go very well, build up pressure so as to shut down, but then kind of have a low roar. Never shuts down. Iíve checked everywhere for leaks. No leaks. I have fully bled the lines. No air in lines. My guess is the pressure switch on the pump is bad. Itís not a big deal at this point simply because we mostly use the camp water. So donít use the pump.
Iíve looked into the cost of a switch, and basically I have to take the pump out to replace the switch. Figure it would be easier just to put in a new pump. Then fix the switch later and have a spare pump.
But if the shurflow pump is prone to breaking like this, anyone have any suggestions on a more durable pump?
Daquenzer is offline   Reply With Quote
Old 05-25-2020, 10:29 PM   #2
SlvrTwinkie's Avatar
1976 29' Ambassador
Logansport , Indiana
When I had to replace my pump last year I didn't want to pay the overly high prices at the local RV stores. So what I did is I hit up my favorite farm store (Rural King) and bought an Everflow pump for around $60. I did go with 2.2 gpm instead of a 3 gpm, which was maybe $20 higher on price. So I that would be my suggestion is to hit up your local farm supply store and see what they have. At Rural King these pumps are located where you find the stuff for the field sprayer supplies.
SlvrTwinkie is offline   Reply With Quote
Old 05-27-2020, 05:59 PM   #3
Well went on the trip. Bought a new pump. Decided not to put in right away. Stopped at the gas station. Decided to use the airstream bathroom. Turned on pump. Worked correctly. Strange. Must have shaken something loose.
Old 05-27-2020, 06:08 PM   #4
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
You scared it into working.
Or maybe the drive did something.
rowiebowie is offline   Reply With Quote
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
