The black plastic cube is the coil of the electromagnet part of the valve. Inside the 'male part' is a spring and a sliding metal 'slug' that the coil moves when you supply voltage to the coil. When you energize the coil, the metal 'slug' opens a valve in the brass part of the valve and lets water flow.
I agree that it's probably an 'auto-fill' for the fresh water tank. Only thing you need to be aware of is that it is capable of overfilling the fresh water tank if you do not pay attention and leave it on too long.
See if you can trace the wires back to a switch on the control panel. That may clear up more of the mystery...
