Old 04-17-2025, 05:50 AM   #1
RMNummi's Avatar
2014 23' International
2022 16' Basecamp
2017 23' International
Saint Petersburg , Florida
Pre-departure water pressure shutoff
Question: you shut off the water pump as part of your pre-departure checklist. Is the system still pressurized? Should I be opening faucets to drain residual pressure? Depressing toilet flush? Dang faucet on my 20 GT 25FBT has turned itself on twice now w sink cover on. Residual water pressure clearly present (and now on floor). Is this just a noob mistake?
RMNummi
TT: 25FBT Globetrotter
TV: 2023 Tundra 1794 Hybrid.
RMNummi is offline   Reply With Quote
Old 04-17-2025, 06:59 AM   #2
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
Pre departure list, turn off pump, flush toilet, open kitchen faucet, replace sink covers, check fridge door, and get a bottle of water for the road! Plus all the other things that need to get done!
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,
1994 Excella 34' 1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 04-17-2025, 07:09 AM   #3
nelsonh's Avatar
2023 23' Flying Cloud
Carroll , Iowa
Essentially, yes, there is still residual pressure in the water lines after you turn off the pump. And yep you can release it by opening the faucets & toilet. So I [try to remember to] open the shower, lav, and kitchen faucets & press the toilet foot pedal briefly before departure to purge the residual water/pressure.
Is this residual pressure in the water lines harmful to "the system" if you don't release it? IMO, not really. But like you say, you can run the risk of a little water coming out during travel if a faucet should open itself. I put rubber bands on the kitchen & lav faucets as a [probably unneeded] precaution, and we never travel with the kitchen sink cover in place since we use the sink as a storage bin for miscellaneous kitchen items while in transit.
'23 Flying Cloud 23FBT #1235 • '24 F150 XLT PowerBoost 7.2kw⚡️ • '10 Border Terrier 🐾
nelsonh is offline   Reply With Quote
Old 04-17-2025, 07:37 AM   #4
Mollysdad's Avatar
Not only departure, but my pump stays off unless I'm actually using it. Same with the water heater.
Old 04-17-2025, 07:57 AM   #5
nelsonh's Avatar
Carroll , Iowa
Agreed! We turn off the pump any time we're going to be away from the rig for more than a half hour. We do leave in on overnight when we're inside because we always have at least 1 toilet flush overnight.....
Old 04-17-2025, 09:29 AM   #6
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If you *don't* turn off the pump at departure there can be an issue:
You bump down the road.
The faucet handle flips up.
The stopper in the sink flips down.
You are greeted by a wall of water when you open the trailer door at the next stop.
If the stopper does not flop down, it's a race between the fresh water tank and the gray water tank to see if you get that wall of water.
Pump off very much *should* be on the departure checklist. Depressurize the lines? Not sure that has much value.
Old 04-17-2025, 09:57 AM   #7
The Panhandle , Idaho
In over 40 years of RVing I have never once experienced a faucet "flipping up" or otherwise turning on while underway. Not saying it can't happen and it is probably a good thing to be aware of. Maybe we've been lucky.
We also store things in the sink while underway so the cover are not in place. In fact, it rarely comes out of storage. Only if we are entertaining inside, itself very rare, and we need the extra counter space.
The only time our pump is left on is overnight and that is rare because we camp primarily with full hookups. It is always turned off when towing.
Hoagie '59
Hoagette '57
Rika - The Aussie Whirlwind
Hoagie is offline   Reply With Quote
Old 04-17-2025, 10:05 AM   #8
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
A faucet turning on or not depends on the brand/model/etc. I've had the kitchen sink turn on once while traveling.
Whether or not to relieve the pressure? Probably a good idea as enough water can come from a faucet with the pump off to cause a mess. But not enough to cause a catastrophe, so no biggie either way.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 04-17-2025, 11:50 AM   #9
1994 30' Excella
Mississauga , Ontario
If you do relieve the pressure before travel you lose that much water. Could be an issue. Maybe not.
Al and Jean
BRN 3845
TAC ON-3
Old 04-17-2025, 12:57 PM   #10
Keys Dave
2021 25' Flying Cloud
Big Torch Key , FL
I'm from the boating world and we always shut off the shore water when you leave the boat for any period of time. A broken water line can sink the boat. As for the pump, under way we often shut it off just because you can't hear it running over the engine noise. Also if no one is using water and the pump starts when you switch it back on you might have a leak in a line somewhere.
Keys Dave is offline   Reply With Quote
Complete bathroom water shutoff. alphamale49 Fresh Water Systems 2 12-25-2021 10:10 AM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Water shutoff valve - help needed AirReg Fresh Water Systems 7 04-20-2014 09:32 AM
Exterior water shutoff valve Ag&Au Fresh Water Systems 14 08-18-2009 09:00 PM
Tentative Departure Date!! pinkflamingoes Our Community 10 06-17-2004 01:44 PM
