Old 07-27-2020, 10:22 AM   #1
2018 16' Sport
Fort Myers , Florida
Plumbing Problems
I have a Bambi Sport 16.
On a trip and haven't used Bambi since December last year.
Having trouble with the water system.
Two questions:
1. When I use city water the fresh water tank is filling to overflow. Found water dripping out of the overflow at the fill point. Is the city water supposed to fill the fresh water tank. Also why is it filling so much.
2. When I use the water from the fresh water tank (city water shut off) pump is noisy and there is also a clicking sound. Pump is a Shurflo. Checked the filter and it is clean. Also made sure the connectors to the pump are tight.
Also checked the city water pressure 40 psi.
Bambi is 2 years old. Never been worked on. Never any problems previously. Just been sat for 6 months stored in a warehouse.
Appreciate comments and thanks.
Dudley
dudleymar15 is offline   Reply With Quote
Old 07-27-2020, 11:18 AM   #2
2002 19' Bambi
Lafayette , California
Search the forum on water pump backflow (or check) valve and you will find a lot of relevant discussion. What is happening for you is typical of that valve malfunctioning.
Tim
Tim A. is offline   Reply With Quote
Old 07-27-2020, 03:19 PM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Get the shurflo kit and replace the head on your pump. No need to replace the pump unless it's failed just the head. If you've already replaced the pump get a couple of the head kits and keep them. You'll need them again.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-27-2020, 03:27 PM   #4
1972 23' Safari
Middletown , Rhode Island
One way valve...
Get a one way valve and install it on the output side of your waterpump. You'll need a 1/2" female to female coupler and a male to male coupler. You can get the kit to fix your waterpump valve but this is easier and will probaly last a lot longer IMO.
https://www.amazon.com/Camco-23303-B...00231742&psc=1
Mx468 is offline   Reply With Quote
Plumbing Problems Bettye Plumbing - Systems & Fixtures 5 07-30-2012 02:36 PM
Plumbing problems airboy 2 General Motorhome Topics 5 04-11-2011 01:44 PM
Plumbing problems jillwill Plumbing - Systems & Fixtures 2 07-01-2009 09:07 AM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
HELP!! Plumbing problems.... mozilla Plumbing - Systems & Fixtures 1 02-26-2004 01:23 PM
