Old 06-08-2020, 01:54 PM   #1
1967 24' Tradewind
Flagstaff , Arizona
Plumbing a 1967 Trade Wind for City Water Connection
I have a 1967 TradeWind. Our Silver Hotdog! It does not have a city water connection and I would like to install one. Does anyone know if there is a reference for installing the plumbing for this? I know the fresh water tank is bypassed. So is there a place after the pump where the city water would enter and then how does it get dispersed through the camper (sink, tub, hotwater heater)? Thanks...Bob
jbobarino3 is offline   Reply With Quote
Old 06-08-2020, 04:06 PM   #2
1966 22' Safari
Fredericksburg , Texas
In our trailers we have the pump adjacent to the fresh water tank. I have bypass valves that I can leave the pump and fresh water tank isolated out of the system. We ran the PEX on the street side at the bottom corner of the wall. The PEX runs through a wardrobe. So, on the street side a couple of inches above the subfloor just behind the street side wheel well we placed a stainless water inlet. When we hook up to city water, we energize the trailer piping with their pressure. We do have backflow preventers and pressure regulators.
Bubba L is offline   Reply With Quote
Old 06-08-2020, 04:24 PM   #3
1966 22' Safari
Hooked the city fill inlet into the cold water trailer line with a shutoff valve.
Old 06-09-2020, 08:05 AM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I believe you can tie a city water connection into the cold water line anywhere downstream of the pump. You will just need a shut off valve or a check valve to prevent backflow.
We generally camp without hookups but even when we have water available we just use it to fill up the tank. I think it probably helps us conserve water usage and filling up the grey water tank.
Dan
Old 06-09-2020, 05:08 PM   #5
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
A reverse flow check valve is required everywhere in the US where juridictions use the standard plumbing code. Just by a water inlet fixture that inlet has one installed.
guskmg
RV Park Water hookup for 1967 Trade Wind jbobarino3 Plumbing - Systems & Fixtures 5 08-06-2018 08:48 AM
Relocating City Water Inlet 69 Trade Wind GoToasterGo Plumbing - Systems & Fixtures 5 11-24-2017 05:34 PM
1967 Trade Wind Water Heater Cover rasmuw Exterior Storage Compartments & Access Doors 1 11-27-2011 05:12 PM
1967 Trade Wind Water Heater rasmuw 1959-69 Tradewind 2 09-10-2009 09:06 PM
Plumbing advice for a '64 trade wind A-Merry-Can Plumbing - Systems & Fixtures 11 03-20-2006 08:25 AM
