10-03-2012, 08:25 AM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Pex- Clamps or Rings
After a lot of reading it seems like Pex will be the way to go when re-plumbing the whole trailer.
Now two questions for the experienced members:
1) Choice of preference between a)the Stainless Steel Cinch clamps or b)the Copper Crimp Rings.
100 PEX 1/2" Stainless Steel Cinch Pex Clamps #100 | eBay
(100) 1/2" PEX Copper Crimp Rings USA 649X2 Sioux Chief | eBay
2) Fittings: Brass or Plastic? not even sure if they are plastic, they may be other material but it looks plastic to the common user like us.
BTW we got a good deal on ebay for the Kobalt Steel Pex Crimp Tool.
Still One Nation under GOD
2 chronicles 7:14
10-03-2012, 08:41 AM
1974 Argosy 20
Kooskia
, Idaho
Brass fittings, either crimp system. The crimp ring system uses a larger tool, harder to get into some spots. The crimp system tool is smaller.
10-03-2012, 09:21 AM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
thanks idroba!
just wondering, what are the major differences between them?
According to Lowes is showing the copper rings as a related item to this tool.
2 chronicles 7:14
10-03-2012, 09:25 AM
1972 27' Overlander
New Haven
, Connecticut
I used the cinch rings. One tool can be used on multiple size rings and removal of the cinch rings is easier than crimp rings.
One bit of warning however. I once was on the road and needed to purchase cinch rings. The local Home Depot did not have them.
10-03-2012, 09:43 AM
bilby05
1962 24' Tradewind
1962 24' Tradewind
Canyon
Pex
I used "shark bite" fittings on our 69 sovereign. They are a little more expensive, but it depends on how many you need. Nice thing about sharkbite is that you can make changes, they remove with a little plastic tool. I am not sure about what it would cost to buy the tools, fittings and clamp rings for the other applications. But I really didn't use all that many and I like being able to make repairs on the road, if something happens to a length of pipe. (you know like wild beavers or plastic eating termites)
best wishes, bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
10-03-2012, 10:08 AM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Hi guys.
thanks for the replies.
We all know how the whole pressure testing works, first one fitting is out, you get it fixed and then under good pressure the next one goes bad and the domino effect kicks in.We fixed our plumbing on our first AS with sharkbite fittings since we were under the impression that it will be just few fittings, once done and doing some numbers and realized that we spent more in patching than replacing everything with pex.
Based on that financial analysis we came to the conclusion that no more patches!
2 chronicles 7:14
10-03-2012, 10:28 AM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
We were ready to order the pex tubing and we saw the option of Oxygen Barrier or Non Oxygen Barrier...?????
2 chronicles 7:14
10-03-2012, 10:37 AM
1979 23' Safari
Wayland
, New York
Non oxygen barrier is fine for plumbing hot and cold otable water. The Oxygen barrier is used for systems that will have lots of steel or cast iron fittings in them, which you won't have in a trailer, also used for radiant flor heating systems.
10-03-2012, 11:09 AM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
cool, thanks for the input!
We were trying to figure why the difference in pricing.
now we found these and they look ok and very handy for the fixtures but not sure how will they do with the crimping, Any idea?
thanks again
2 chronicles 7:14
10-03-2012, 11:47 AM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
sorry forgot the link!
We found these and since we are thinking on placing a valve in every fixture they look handy and not pricy
Lot of 10 PEX 1/2 x 1/2 x 1/2 MPT Poly T Tee Fittings | eBay
2 chronicles 7:14
10-03-2012, 11:55 AM
1988 25' Excella
1987 32' Excella
Knoxville
I guess you will use what the tool you got on ebay is for! It looks like the tool for the stainless steel cinch clamps. About 40 bucks at Lowes. They work fine. Never used the copper rings, so I can not compare. I use the brass fittings. I reccomend spending another 10 bucks or so and getting the cutter for the pex from Lowes or HD. A nice, square, clean cut goes a long ways towards making a trouble free connection.
10-03-2012, 12:08 PM
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
I use the copper rings. I've done four complete Airstream plumbing systems and never had even one leak. One of the PEX installations has been on the road for four years and 20,000+ miles and one of the other ones for 3 years and 10,000+ miles.
I also worry about repairs on the road, but it's looking like a failure isn't a significant risk.
Zep
10-03-2012, 01:00 PM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Hi Bill
Not you got me worried!
We were under the impression that is a crimping tool, and we were most likely going with the copper rings.
This is the one according to Lowe's
Shop Kobalt Steel PEX Crimp Tool Kit at Lowes.com
And this is the link from the auction that we won...
Kobalt Quick-Cinch PEX Clamp Tool | eBay
So...Now I'm sweating! just order the rings on ebay and don't even know what tool we have
2 chronicles 7:14
10-03-2012, 01:03 PM
1973 23' Safari
1977 23' Safari
Palmer Lake
Originally Posted by VeggieBullet
...We were under the impression that is a crimping tool, and we were most likely going with the copper rings...
it looks exactly like my ring crimping tool.
10-03-2012, 01:13 PM
1970 31' Sovereign
Burnsville
Just finioshed replumbing my '71 Sovereign and recommend the stainless steel cinch clamps because (1) the tool is cheaper and (2) they are easier to use in tight spaces. Having said that, I have not learned of an "east" way to remove them from a fitting. Any suggestions? Thanks, Bill
10-03-2012, 01:14 PM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Hi Zeppelinium!
Thanks for the input, it makes me feel better that we are not ordering all the wrong parts and that it will take me a week once we get them to notice that !!
We are also getting these fittings
1/2 Brass Elbows (25)
1/2 Brass Tees (25)
Copper Rings (100)
so based on your experience would that be enough?
2 chronicles 7:14
10-03-2012, 01:15 PM
1988 25' Excella
1987 32' Excella
Knoxville
Guess you got it right then. From afar it looks a bit like the cinch tool too. I guess you will be going with the copper rings then.
Have had to remove cinched rings from from a fitting several times. Did not find an easy way. I cut a angled cut across the ring with a hacksaw or a dremel with a wheel. Not too hard to do. You can cut most of the way and break it with a screwdriver sometimes. I think there may be a cutting tool for that but I try to keep it down to a minimun and it is not very hard to do with the hacksaw.
10-03-2012, 01:27 PM
1977 23' Safari
Niagara on the Lake
Word of Warning
I broke one of my personal rules and borrowed a crimp tool from a friend of my fathers, he didn't tell me it need to be calibrated/adjusted periodically and I had no instructions other than him showing me how it worked on the bench. This is one of the many reasons I never borrow or loan tools.
Everysingle crimp leaked and had to be redone! and you'r not supposed to re-crimp the rings either.
Make sure you use the gauge and adjust as necessary.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
10-03-2012, 01:30 PM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Hi Bill
Now we are looking for the cutter as you recommended, but the center of the tool looks like a cutter, may be not..
2 chronicles 7:14
10-03-2012, 01:36 PM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Originally Posted by AldeanFan
Word of Warning
thanks for the warning!
now this doesn't have any instructions, so now what...
2 chronicles 7:14
