Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 05-25-2018, 11:06 AM   #1
2007 27' Safari FB SE
BENSON , Arizona
Partial blockage of fresh water flow
Fresh water coming in the rig has good flow.
I have good flow from faucets in shower and bathroom/toilet.
The galley sink is very restricted just above a trickle. The screen at the end of the faucet is clear. Is there another screen to clean within the faucet or "upstream" from the faucet. I don't want to take the faucet apart if it is not necessary.
Thanks for your help.
ebiz is offline   Reply With Quote
Old 05-25-2018, 09:20 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Is the low flow the same on discrete hot and cold positions?
When did this start?
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-26-2018, 07:13 AM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Do you have one of those faucets with a pull out sprayer head? If so, pull it out and see if you get more flow.
CRH is offline   Reply With Quote
Old 05-26-2018, 11:08 AM   #4
BENSON , Arizona
Thanks for the replies. Firstly, this started after about 3 months in storage and the faucet does not have a pull out sprayer.
I'm thinking about changing the ceramic cartridge in the stem although I have had it out and it "appears" clean.
I am getting to a solution using a collapsing square search!
Cheers
Old 05-26-2018, 04:25 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
This really sounds like some junk got into the FW system. Does the water work ok on pump? (Turn off City)...
I had some scale break loose in the Water heater and clogged lines... took some air pressure and patience to get it running WITHOUT filters or the aeration... then put aerator back on only to find they were clogged too!!
Remember.. leave no turn unstoned... :/
Channing
WBCCI# 30676
Old 05-29-2018, 08:46 AM   #6
BENSON , Arizona
Thanks for all your replies. I'm still picking away and am thinking it is probably some bit of stuff blocking the system I get the same results when I use just the water pump.
Cheers,
Water line blockage robtan Fresh Water Systems 10 08-27-2020 12:01 AM
Water heater and water flow? GypsyKarma Water Heaters, Filters & Pumps 17 12-06-2016 03:42 AM
Black tank blockage! NwilcoxM Waste Systems, Tanks & Totes 30 05-30-2014 02:37 PM
No water flow after hooking to city water Grevers911 Fresh Water Systems 8 06-23-2013 10:08 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
