RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-28-2020, 10:55 PM   #1
HankO's Avatar
1997 28' Excella
Eden , Utah
Ok I've really done it now!
After being hit with a cold snap in Salmon, Idaho for 3 days I turned the water back into the trailer and found leak on a T that seems to be the Cold water line coming in from the line that is connected to the the outside connection.
I cut out the the tee and was in the process of fixing it when I put a little too much pressure on the pipe and it broke on a 90* elbow behind the hot water tank against the outside wall, the elbow is in a impossible spot to fix from inside the trailer. It looks like to me, my only solution to fixing this pipe is to get that tank out of there somehow so I can have access to that broken elbow.
Has anyone had to fix a pipe behind there hot water tank and if so what am I up against.
Hank O
HankO is offline   Reply With Quote
Really, really new Bambi! Pahaska Off Topic Forum 3 05-12-2009 09:20 AM
Really, really new!! Globeville Member Introductions 6 08-20-2007 04:33 PM
Really, Really, Really Hot swebster Airstream Motorhome Forums 8 11-16-2003 09:46 PM
Really really great site and Airstream FrankR On The Road... 5 07-14-2002 03:10 PM
