Old 08-06-2020, 04:25 PM   #1
2013 19' International
Stockton , California
No water to toilet or bathroom sink
We have water to the shower and kitchen sink, but none in the toilet or bathroom sink. That's using either the tank water or city water. We tried both and still no water in the toilet or bathroom sink.
Buck1948 is offline   Reply With Quote
Old 08-06-2020, 04:41 PM   #2
2018 25' International
Slidell , Louisiana
There are shut-off valves to the sink and toilet. Perhaps they were closed for winterizing.....
BayouBiker is offline   Reply With Quote
Old 08-07-2020, 08:19 AM   #3
We are the original owners. It's never been wintered. Also, we have not turned the valves under the sink or toilet. When we turn on the kitchen sink water sputters then runs. The shower works normally. Haven't seen any kinked hoses or any other problems by looking under the sinks. Thanks
Old 08-07-2020, 08:51 AM   #4
Slidell , Louisiana
That's very odd. The hot and cold water is independent once it leaves the water heater area, but there is a common cold over to the side of the trailer that seems to be not working and it also feeds the water heater. Can you confirm you have both hot and cold to the shower and galley?
Old 08-07-2020, 09:16 AM   #5
2015 25' FB International
EVERGREEN , Colorado
Bathroom sink
Unscrew the cap on the tap..it gets filled with crytal junk over the winter and clean it out
Pdunbar is offline   Reply With Quote
Old 08-07-2020, 09:17 AM   #6
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Just spit-balling here, but my Avenue class B lost water flow to the toilet and the cold bath faucet. Had some mineral gunk in the cold water side. The washers had screens at the connections and were almost completely blocked. But it didn't happen overnight, but fairly quickly. And always had hot water at the bath faucet.
rowiebowie is offline   Reply With Quote
Old 08-07-2020, 12:12 PM   #7
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Had the same problem with the toilet in my 75’ I had to replace the valve, it was mineral deposits. You could soak the parts in vinegar. If that is the case.
bibbs is offline   Reply With Quote
Old 08-08-2020, 12:51 PM   #8
I'd like to thank everyone that replied with helpful advice.
The problem with the sink was a clogged filter which I cleaned. Problem solved! The toilet - I removed the toilet and cleaned all the calcium that was blocking the water flow. Re-installed the toilet and it works great! Thank so much:-))
Bathroom Sink Water: Does it go to grey or black tank? chaseav 2011 - 2015 International 45 08-04-2016 05:49 PM
Atwood Tankless Water Heater - Will Only Ignite When I Turn On the Bathroom Sink sonyamontana Water Heaters, Filters & Pumps 7 07-11-2016 07:36 PM
How do I remove leaky sink drain pipe, bathroom sink, 1970 Sovereign NevaH Plumbing - Systems & Fixtures 4 09-14-2015 04:01 PM
Water Damage in Floor Under Bathroom Sink? breezyway Repairing/Replacing Floor &/or Frame 3 11-09-2013 06:42 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
