Old 08-12-2020, 06:37 PM   #1
kbmwrs's Avatar
Morgan Hill , California
New bathroom faucet install?
HI thank you to all that respond.
2016 25FB International
Bought a new faucet with more distance from single hole to water coming out of spigot......better to get your hands under.
Seems simple to trade out.
But when I started to unscrew the water lines.....there was water pressure. Quickly stopped.
I do NOT have water line hooked to shore water NOR do I have the pump on.
I DID prior but not for a full day now.
Is this just residual pressure? I released some water from the kitchen faucet.
Should I expect more water when I undo the bathroom water lines?
Is there a lower (than bathroom sink) valve I can drain the system?
Thank you.
kbmwrs is offline   Reply With Quote
Old 08-12-2020, 07:32 PM   #2
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
You should be fine now the pressure is relieved but you can also open low point drains to drain the interior plumbing first. Check your manual for location. They drain beneath the trailer.
Peter
Instagram: @thealuminumtent
pcskier is offline   Reply With Quote
Old 08-12-2020, 11:21 PM   #3
kbmwrs's Avatar
Ah ut being that I bought it used....I didn't get a manual.Didn't think of it at the time of purchase either.
So there should be a petcock under.....what area do you think?
Old 08-12-2020, 11:25 PM   #4
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
Look underneath your trailer. Wherever you see tubes sticking out, look in the same spot inside the trailer. There will be valves to open.
Here is your manual: https://www.google.com/url?sa=t&rct=...aGBeUtEeMFMQD_
Peter
Old 08-13-2020, 12:08 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, check by your water pump; You might have an accumulator tank. This keeps some pressure in the lines. Helps keep the water pump quiet.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-13-2020, 09:44 AM   #6
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
I would like to replace ours. What faucet did you purchase?
A link to the item would be most helpful as opposed to a description.
Would like to hear of any other issues you may encounter doing the replacement.
Greg
greghoro is offline   Reply With Quote
Old 08-13-2020, 09:50 AM   #7
MacCoroner's Avatar
2018 22' Sport
Manchester , New Hampshire
Release pressure.
I just replaced our bathroom sink faucet and I opened the outdoor shower faucets to release the pressure. I have a 22FB and the outdoor shower is lower than the bath fixture so it worked well.
Cheers,
MacCoroner is offline   Reply With Quote
Old 08-13-2020, 11:53 AM   #8
Lowell , Arkansas
Just replaced the Moen w/a like Moen from Lowes. Turned off pump, drained the pressure off. I found it helpful to remove the sink for easy access, plus I got to reseal the sink. Everything went well! 2007 25' Safari.
J. L. Taylor is offline   Reply With Quote
Old 08-13-2020, 12:19 PM   #9
kbmwrs's Avatar
Next problem.
How to connect the 3/8" female connector on the new faucet to the ? sized female of the AS plumbing?
I tried the local hardware store. Seems the AS plumbing is NOT standard.
I need a male/male connector...but what size? male 3/8" to ?
Old 08-13-2020, 02:52 PM   #10
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
It should be standard size plumbing fittings, take what came off the AS to the store, the water heater can trap air therefore causing the pressure, this is a good sign means there are no leeks. Once you bleed off the pressure just put an old towel down to catch the remaining water there won’t be much.
bibbs is offline   Reply With Quote
Old 08-13-2020, 02:55 PM   #11
kbmwrs's Avatar
Originally Posted by bibbs View Post
It should be standard size plumbing fittings, take what came off the AS to the store, the water heater can trap air therefore causing the pressure, this is a good sign means there are no leeks. Once you bleed off the pressure just put an old towel down to catch the remaining water there wonít be much.
Nope its not.
Took AS faucet to HW store. NON-standard fitting.
Got a SharkBite valve for PEX to 3/8" faucet connector.
Now SharkBite leaks at PEX...only one...one is good.
Old 08-13-2020, 05:38 PM   #12
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
Nope its not.
well welcome to the club...seems nothing is easy on a camper.....as you will find, we are not fans of sharkbite fittings.....because they leak often....I would encourage you to take your non standard tubing to a plumbing supply store, not home depot or lowes....the guys that know about plumbing will be able to identify your product.....
....having said that, my Airstream has all pex plumbing, but it is the pex that only comes from home depot....it seems home depot made arrangements to have a product manufactured just for them.....but I got that info from a guy at a real plumbing supply house.....smh
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
mkcurtiss is offline   Reply With Quote
Old 08-14-2020, 09:03 AM   #13
kbmwrs's Avatar
Thanks all. I installed the SharkBite fittings/valves. I'll keep an eye on them.
Old 08-14-2020, 10:36 AM   #14
2007 22' International CCD
Iíve had no issues using PEX and fittings from the big box stores both Loweís and Home Depot.
I donít use sharkbite fittings in the Airstreamís plumbing system for permanent repairs. I figure their o-rings wonít last. And Iíd rather not have to worry about them.
I do use the brass fittings instead of the cheaper plastic ones. A few cents more per fitting is worth the peace of mind.
rmkrum is online now   Reply With Quote
Old 08-14-2020, 11:37 AM   #15
bibbs's Avatar
1975 26' Argosy 26
Vista , California
Plumbing can make a person grouchy! Mkcurtiss said it ! Go to a plumbing supply house.
Bathroom Faucet input Dan@LED4RV Sinks, Showers & Toilets 7 07-04-2008 06:20 AM
'72 Ambassador Repair of Furnace and Bathroom Faucet tdveal General Repair Forum 6 02-28-2008 05:16 PM
Bathroom faucet repair / replacement jesus mike Sinks, Showers & Toilets 7 06-08-2007 10:36 PM
Bathroom faucet replacement billwhelan Fresh Water Systems 1 09-20-2004 08:12 PM
Bathroom faucet and toilet stuff Safari Tim Sinks, Showers & Toilets 5 07-07-2004 04:14 PM
