Old 06-18-2021, 02:29 PM   #1
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
My Pentair Shurflo 4008 sounds like a Gatling Gun (vintage)
I don't know if it's just my unit but the Pentair Shurflo 4008 water pump is ridiculously loud.
I added inflow and outflow tubing, unscrewed the unit from the floor and placed it on a piece of foam to absorb the reverberation but it still sounds just like those old Gatling Guns in the movies; it's an embarrassment. Adding an accumulator won't make much of a difference since at one point you need to fill the accumulator (in addition Pentair writes in their documentation "no accumulator needed" for the 4008).
There were folks in past threads that seemed to indicate that their pump was silent. What make and model do you have that is so silent?
I will have a dual purpose Pentair Shurflo for sale in the not too distant future, it pumps water and scares off bears!
2016 International Signature CCD (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 06-18-2021, 03:03 PM   #2
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
Hermes
I had a loud shurflo 4008 but found it wasnít the pump as much as a pex line against the side of the coach under the bathroom sink. Secured the line with a zip tie and the sound greatly diminished. Also after talking with Shurflo tech dept the said you can certainly add the accumulator if you like but itís not necessary. However the tech I spoke with recommended it. So I added an accumulator. Seems to help on the start up pressure but not sure it made it any quieter. Also my filter was upside down. Clear bowl on top causing trapped air. Shurflo says the clear bowl must be on the bottom in order to get filtration. Hope this helps
JDG is online now   Reply With Quote
Water pump sounds like Tommy gun s1000pre Plumbing - Systems & Fixtures 9 02-17-2021 04:55 PM
Sounds like the heat pump is running s1000pre Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-30-2020 05:30 PM
Replacing a Sureflow Revolution 4008 3gpm pump. Do I need to? Marygb Water Heaters, Filters & Pumps 10 01-13-2019 11:23 AM
Rivets, rivet gun and brazier gun ? GaŽl Ribs, Skins & Rivets 33 03-27-2014 08:27 AM
