Old 09-09-2023, 12:52 PM   #1
1983 34' Limited
Harahan , Louisiana
Monitoring
I am restoring a 1983 34’ classic- center bath. While I have the trailer raised and the fresh water tank out, I want to replace the probes and possibly the monitoring system. Has anyone tried the tech-edge I-series system yet?
Dariwuz is offline   Reply With Quote
Old 09-09-2023, 08:26 PM   #2
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
We’d all like options over Sea-Level but given how hard it is to change these sensors after they are installed I’m not sure I’d trust such a tiny little company out in the countryside. Try a google map. https://maps.app.goo.gl/BfRSehWi31XeMxYw6?g_st=ic
I’d stick with Sea-Level.
daleyocum is offline   Reply With Quote
Old 09-10-2023, 07:10 AM   #3
1983 34' Limited
Harahan , Louisiana
That’s just it. My trailer is all original and nothing works, so I’m basically starting from scratch. I have the trailer raised and have access to all the tanks, so why not start over. I’m just doing research at the moment….. my tanks are held in place with large metal covers. I understand that seelevel has issues with metal in close proximity…… although I like the idea of not using the in tank probes. It just seems to me that with all the tech available there should be a better way to monitor the tanks
Old 09-11-2023, 10:43 AM   #4
daleyocum's Avatar
Portland , Oregon
Absolutely avoid probes and floats inside the tanks! Sea level is probably the best game in town. Their tech support may be able to advise you on how close other metal can be.
Old 09-12-2023, 07:29 AM   #5
1983 34' Limited
Harahan , Louisiana
Thank you. I will give them a call
PressurePro Tire Pressure Monitoring System 68 Overlander Commercial Listings 21 09-21-2007 03:49 PM
Re: Electric Monitoring System joossens Electrical - Systems, Generators, Batteries & Solar 9 08-11-2007 02:08 PM
PressurePro Tire Monitoring, at last dtbw Tires 14 06-01-2004 07:40 PM
Diesel Monitoring Gauges 53flyingcloud Mechanics Corner - Engines, Transmission & More... 1 04-14-2003 07:40 AM
Engine Monitoring, gauges etc. thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 07-25-2002 02:25 PM
