Low water pressure at toilet only
I'm on my first trip after winterizing in October by blowing out the lines. I'm hooked up to city water at an RV park, and water pressure is very low in the toilet; just trickles of water come out when flushed. I don't believe it would flush solid waste, although I am definitely not going to try. However, water pressure is normal in the galley sink, bathroom sink, and shower.
The first time I flushed the toilet on this trip it was from the fresh water tank using the water pump, and it flushed okay, but there was some unusual sounds.
Is it a reasonable guess that some mineral deposits or scaling was shaken loose when the water lines began to fill, and those are now partially clogging the line to the toilet? Is there some other possibility I'm not thinking of?
If it is mineral deposits, what is the process to repair this?
Thanks for any thoughts or suggestions.
