Old 12-30-2017, 12:47 PM   #1
2015 27' FB International
Fair Oaks Ranch , Texas
Low Point Drains After Anti Freeze
Should low-point drains be open or closed after antifreeze is pumped into all lines?
Thomas2 is offline   Reply With Quote
Old 12-30-2017, 01:33 PM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I quickly open and then close again, after I have confirmed that the pink anti-freeze comes out. This protects the valves in case some water was trapped above the valve. If you leave the valves open, all or most of the anti freeze you put in the lines will drain out. Make sure you "flush" the toilet until anti freeze is seen entering the bowl.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34' 1987 Limited 34'
1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 12-30-2017, 01:33 PM   #3
Sag Harbor , New York
Ditto. If your low point drains were not open when you pumped AF into the lines, there may be water still trapped at those "dead end" supply line locations.
If, however, you opened the LP drains, until AF ran out, and then closed the drains, you should be OK.
These sort of nuances of using AF are why we never use it [for the supply pipes H/C]. Just compressed air to blow out all supply lines, etc..
Happy New Year!
Peter
Old 12-31-2017, 12:29 PM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Once I see the pink stuff, I close the valves,
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 12-31-2017, 07:32 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Low point drains are considered just another "faucet". Open them and let the pink RV antifreeze dribble out and then close them up again.
I blew the water out of my 75 Overlander. Every faucet was nothing but air. The low point drains were then opened and a blew air until they were nothing but air.
Then I removed the old copper plumbing lines from the trailer. I was shocked at how much water was still in the lines. It may not have been enough to bust a copper pipe, but I decided the air blow method is just not good enough for me. Low point drains are even less effective in my view.
Pump in RV antifreeze everywhere after the air blow process and you're ready for winter.
David
30' International CCD low point drains? LivLoveLaugh 2011 - 2015 International 5 04-19-2013 07:12 PM
Low point drains in 2012 Mike-Gloria 2011 - 2015 Classic (all lengths) 3 03-18-2013 09:04 AM
2010 27FB Low Point Drains PJohnson Winterizing, Storage, Carports & Covers 2 10-31-2010 12:17 PM
front low point drains, 19' int'l ericwarren Winterizing, Storage, Carports & Covers 3 12-18-2008 02:58 PM
Low point drains runningbarre Winterizing, Storage, Carports & Covers 5 09-25-2008 06:07 AM
