Old 01-28-2023, 05:13 PM   #1
2019 25' Flying Cloud
Houston , Texas
Low cold water pressure some outlets
2019 FC 25RB. De-winterizing. I have quite low water pressure at the two sinks and outside shower. Pressure is OK at the inside shower and toilet. Same whether city water or pump. Hot is fine. Any thoughts on what to look for? I am thinking about blowing compressed air through the system.
DCPAS is offline   Reply With Quote
Old 01-28-2023, 07:35 PM   #2
Aurora , Colorado
The exact thing happened to my Airstream, the aerators were clogged with the winterizing fluid. As suggest soak in vinegar and the problem solved. The moen aerator sometimes requires a special wrench to remove, I found them at Lowes a set of 4 sizes comes on a key ring for around $10.00.
starfishscub is offline   Reply With Quote
Old 01-29-2023, 06:34 AM   #3
Houston , Texas
Thanks, but it's not the aerators. I checked that and, anyway, the hot side has good pressure through the same faucets.
Old 01-29-2023, 06:53 AM   #4
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Might need to pull the cold valve assy and inspect/clean.
GCinSC2 is offline   Reply With Quote
Old 01-29-2023, 09:42 AM   #5
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
If you have a hot water tank then you have a mixing valve attached to it. That is notorious for being problematic after dewinterization. It has filter screens as well as internal mechanisms that could fail. Your failure mode is weird though.
daleyocum is offline   Reply With Quote
Old 01-29-2023, 11:51 AM   #6
daleyocum's Avatar
Portland , Oregon
Another idea. Some trailers have a separate water filter for the cold water of the sinks. You might check under the kitchen and bath sinks and see if that applies to you. If so, there’s the problem!
Old 01-29-2023, 12:32 PM   #7
Houston , Texas
Yeah, I think I have that problem too now. The cold water got better after I put compressed air through. Apparently dislodged whatever was there. Thanks.
Old 01-29-2023, 03:35 PM   #8
daleyocum's Avatar
Portland , Oregon
Glad to hear it got better. Be sure to heat up the hot water tank and see if the hot water, and cold water, come out at the temperature and flow you expect. I’ve been through two mixing valves so far, always discovered when dewinterizing.
Low Gas Pressure: Low stove flame, hot water heater won’t ignite. tjwoods1 LP Gas, Piping, Tanks & Regulators 16 10-19-2018 02:56 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
