Old 04-07-2021, 11:24 AM   #1
Los Angeles , California
Wink Leaking Water
Hi --
I have a 1972 Airstream 31 sovereign land yacht and when I attached the water to the main line no water came out of the faucets and there was a leak coming from the rear bathroom.
1. How do I access the pipes to see what is going on?
2. Are there any valves or something that I should turn when attaching the water?
Any insight would be helpful!
Thanks!
E
Eva Pfeffer is offline   Reply With Quote
Old 04-07-2021, 03:11 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had a 75 TradeWind and much of the plumbing was viewable from under the bathroom sink. Most of the pipes are inside of the trailer. If you still have the original copper pipes, you might consider replacing them with Pex. Copper does not do well when water freezes in the pipe.
Richard
Water Leaking at Wheel Well when water is hooked up Lauren25 Plumbing - Systems & Fixtures 18 12-28-2017 08:34 PM
Help! Water Leaking into my Fresh Water Tank dasams Fresh Water Systems 15 06-21-2017 08:57 PM
Water leaking from fresh water input 3dawgnight Plumbing - Systems & Fixtures 2 10-24-2016 11:01 PM
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 11:38 AM
Water leaking when connecting city water- mystery hose nozzle Romelio Fresh Water Systems 1 11-16-2015 06:01 PM
