Old 09-26-2020, 04:11 PM   #1
1994 30' Excella
Alameda , California
Leaking shower connection
In my 1994 Excella, the shower cord connects to this thing (not sure the name) via a plastic knob (which looks designed to increase shower pressure). I bought a new shower head and cord but I realized that did me no good, the problem is the connection. What is this plastic doohickey called and where do I get one? Click image for larger version
UrnLahzer is offline   Reply With Quote
Old 09-26-2020, 05:47 PM   #2
2002 19' Bambi
Lafayette , California
It looks to be a vacuum breaker (anti-backflow device). Here are a number to choose from: https://www.amazon.com/s?k=vacuum+br...b_sb_ss_i_2_23
Tim
Tim A. is online now   Reply With Quote
Old 09-26-2020, 06:57 PM   #3
rd tighe's Avatar
2007 25' International CCD FB
South , Texas
Images: 12
We removed ours
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' FB International CCD Solar
2019 Toyota Tundra
rd tighe is offline   Reply With Quote
Old 09-27-2020, 07:32 AM   #4
1994 30' Excella
Tim
Thank you!
Old 09-27-2020, 07:33 AM   #5
1994 30' Excella
Originally Posted by rd tighe View Post
We removed ours
Interesting. But the shower hose is a different size. Did you just connect via an adapter?
Old 09-28-2020, 06:00 PM   #6
rd tighe's Avatar
South , Texas
Images: 12
We didn't have any problem the new shower hose screwed right on
W.B.C.C.I. 5617
2019 Toyota Tundra
Old 09-29-2020, 09:02 AM   #7
1994 30' Excella
If I remove the vacuum breaker, I have two female connections, neither of which appears to be NPT (assuming NPT is "pipe thread"; when I removed the vacuum breaker to take it to the local hardware store, the thread wouldn't work with normal pipe fittings and the hardware employee said that the thread was different from "pipe thread").
So two questions:
1) even if I get a new vacuum breaker I have a two female connection problem because the vacuum breakers are M/F and the shower hose is F.
2) what is the thread type on these fittings?
Thank you!
Old 09-29-2020, 11:17 AM   #8
2002 19' Bambi
I think you left part of the old vacuum breaker in place and that is why you have two female connections. In the attached image, the part outlined in red should also be removed. Our 2002 has exactly the same fitting coming out of the shower wall and there is no problem attaching a vacuum breaker with a standard thread to it.
Tim
Old 09-29-2020, 10:19 PM   #9
1994 30' Excella
Thanks, Tim! I’m clearly a n00b.
Old 10-19-2020, 05:40 PM   #10
jsamuel8's Avatar
2002 30' Classic S/O
Sierra Vista , Arizona
Mine was leaking the last time I took a shower. Am awaiting a new one from ODMRV. They don't look difficult to remove?
jsamuel8 is offline   Reply With Quote
Old 10-19-2020, 06:47 PM   #11
2002 19' Bambi
Normally they are easy to remove unless they have been over-tightened or corrosion prevents unscrewing them. Almost all such vacuum breakers seem to leak slightly when the shower is running, so don't be too surprised if your new one also drips a bit.
Tim
Old 10-19-2020, 07:35 PM   #12
jsamuel8's Avatar
Thanks Tim. My coach will be 19 this December so hopefully she will let go of it with not much effort. I have been using a water softener for the past seven years which should help as well! I will let you know once completed. Again thank you!
Old 10-25-2020, 03:25 PM   #13
jsamuel8's Avatar
Replaced yesterday with no issues; minimal force required to loosen the old one. Wasn't connected to city water and my tank was empty. Will get her out shortly and test.
Old 11-15-2020, 05:59 AM   #14
jsamuel8's Avatar
Hooked up city water yesterday; worked beautifully! Taking her to Roper Lake SP for the Thanksgiving week. Looking forward to the increased water pressure! Take care; thanks for all your help!
Leaking pex connection slawnugget Sinks, Showers & Toilets 2 02-28-2020 09:28 PM
City Water connection leaking on inside of trailer bambiangel Plumbing - Systems & Fixtures 2 05-02-2017 04:19 PM
hose clamp connection leaking mnboy1960 Waste Systems, Tanks & Totes 13 10-07-2013 06:29 AM
Part missing? leaking shower connection glacierrunne Sinks, Showers & Toilets 3 07-18-2006 09:33 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
