RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-26-2020, 07:25 PM   #1
2020 22' Caravel
SAN TAN VLY , Arizona
Unhappy Leaking over my holding tanks?! slow drip
Hi There! I am full timing in my Airstream. Only made it 6 weeks and list of problems. Now I am at the campsite, only ever been on city water and there is a slow drip coming from over my black and gray tank flush. It doesn't smell so I am thinking fresh water, but no idea. I have only had my 2020 Caravel FB since June and already spent more time in the shop than on the road. Of course I am all the way up in Washington state, and closest Airstream is 2 hours away. Any advice on what I can do would be greatly appreciated? I drained fresh, disconnected from city water and still leaks. Dumped all tanks and still constant drip each second. I am not wanting to try to find accommodations for the dog and I. Airstream in AZ took me 3 weeks to get into service after first week of purchase. Then they had it for 4 weeks for what they said were "user error". Total newbie, but not that daft.
AndieJay803 is offline   Reply With Quote
Old 10-26-2020, 07:51 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Check the connection on the back side of the city water inlet they sometime just need a quarter turn to solve your problem.
Old 10-26-2020, 07:53 PM   #3
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Hi,if your going to Covington Wash Airstream you will probably be served better than before,I bought my 23FB their back in 2012 and they do well in service with that said you need to be more firm in getting this issue addressed. You might just have what I had with my 23FB, that was the shower waste was loose and it leaked from there. If you may picture though the tanks are empty your holding water in the sheet metal bay that hold the tanks and that why you continue to see water dripping.
Hope you get it solved ASAP
Laurence
LAWBC is offline   Reply With Quote
Old 10-26-2020, 11:50 PM   #4
2020 22' Caravel
That gives me some hope! Thank you. I have not had any good times at the dealers
Old 10-27-2020, 12:00 AM   #5
2020 22' Caravel
Picture of leak
So I had tried readjusting the water intake but it is actually dripping from under the metal plate above the dump valve. I’m trying to attach a pic if that helps anyone troubleshoot with me!
Thanks for all the suggestions.
Old 10-27-2020, 07:12 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard 👍
Is the fresh water tank full? Are you still connected to camp water?
Out FW tank will leak when full until the level drops below the vent line on the tank.
Disconnect and FW & see if the leak stops.
Sweet Streams
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Change is the new normal, if nothing changes, nothing is normal, everything changes, everything is normal.”
RLC
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 10-27-2020, 10:27 AM   #7
2020 22' Caravel
Thanks for help!
Hi Guys,
Yup, tried disconnecting from city water. Still dripping. Emptied the FW tank. Still dripping. Emptied the grey tank. Still dripping. Black tank dump. Still dripping....thank you sweet baby geebus, not my black tank leaking, I hope, I am not polluting. LOL! Still constant drip. Drained hot water tank, so I think, but I had another forum say you can't truly get rid of all the water in my lines without compressor air, etc. So I guess I am off to Airstream, 3xs in 3 months of purchase.....Puhleeeease tell me this gets better?! I am so hopeful and love my silver nugget. I knew there would be regular maintenance but much more of what I could fix, than this!
Fingers crossed in and out quick with puppers and not too much loss of deposits and money with my current campsites.
-Andie and Nala back to civilization XOXOXOX
Old 10-27-2020, 10:55 AM   #8
2020 30' Classic
Blue Ridge , Georgia
Just a thought but are you using your AC and are sure its not the AC condensation line causing the drip?
Gleverett is offline   Reply With Quote
Old 10-27-2020, 12:04 PM   #9
LAWBC's Avatar
Quality control @ the factory
To:AndieJay803
Yes it does get better once you get past the deficiency list.
What we have here is a failure by Airstream to verify by pressure testing all water systems plumbers do in new housing/ commercial construction more so in our trailers.
Laurence
Old 10-27-2020, 04:09 PM   #10
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
First off, AndieJay, Welcome!
I’m perplexed by the description that you’ve unhooked from city water, emptied all the tanks and still have the drip. A few things to consider and try...
- If you change the level on the trailer (front to back or side to side) does the leak emerge from a different point?
- When you drained everything did you turn off the water pump and open a faucet to relieve the fresh water system of pressure? Any change in drip rate? A slow drip in the supply system can take surprisingly long to relieve past system pressure.
- What’s generally above that point on your floor plan? Could there be a leaking sink trap or shower pan that slowly feeds water even after feed sources are off? Those leaks in the drain side of a house or Airstream don’t stop or slow when systems are turned off and drained.
- As Gleverett suggested, this may not be a plumbing leak at all. AC condensate can flow off the roof and appear in crazy places. Overnight dew can do the same (but usually dries up quickly as the day warms). Any chance it’s one of those? Even the fridge has a drain and could drip if there is a problem with the gasket or other seals.
This sounds like a typical Airstream mystery... but one that probably has a solution and based on what you’ve learned so far may not be serious. I’ve changed a black tank dump valve during a trip... I’m confident that you are not in that kind of trouble!
Keep us posted. You’ve got empathetic technical support here!
GammaDog is offline   Reply With Quote
Old 10-27-2020, 04:24 PM   #11
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi AndieJay80,*
We're very sorry to learn about the issues you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can learn more and share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 10-31-2020, 10:05 AM   #12
2020 16' Caravel
Orange City , Florida
Thank you! We kept hearing a drip and after reading your comment we did the quarter turn and our drip stopped immediately.
Our concern now is that it was dripping for about a week. Have we done damage to our flooring with the water leak? Not sure that leak for a week would do damage but we’re in a humid cold area that things do not dry out quickly right now.
Thanks again!
Srwpnh is offline   Reply With Quote
Drip, drip, drip. Or not to drip? Vitaver Plumbing - Systems & Fixtures 9 12-19-2016 08:25 PM
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 08:32 AM
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 09:04 PM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 09:22 PM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 03:05 PM
